Question about Canon Office Equipment & Supplies
Paper keeps getting stuck
When I go to print...paper gets stuck and says paper jam..pull it out..it prnts then th enext print job..stuck again
  • Tim Swiercinsky May 11, 2010
    What model of Canon copier are we dealing with?
  • Anonymous Mar 17, 2014
    says there is a paper jam and will not print. however there is no paper stucl
  • 92 Answers
See if the paper sensor are jam or if the machine have paper jam.
Posted on Jul 06, 2009
Printer gives mesasage of jammed paper and will not print
Hi Pedro,
This means the printing paper maybe stuck.
  • Turn the printer off and on.This sometimes clears jam automatically.In case it doesn't:-
  • You need to gently pull the paper out from the rear tray or from the output slot.
  • In case it tears,turn the printer off and open the printhead cover and remove the papers carefully not to touch anything inside.Close the cover.
  • Load printing papers again and press RESUME on the printer to print queued print jobs.
Hope this helps.Thanks!
Please rate this answer.
Oct 20, 2011 | Canon iP100 Portable Printer
Hi, Sirs; My name is Heiman, Today I have one question want to request you that, I can not push to stop the button of paper jam in appear a flashing error on the printer. And also when I want to print...
Paper jam means a paper has got stuck up on your printer. open the printer and see if you can carefully pull the paper that has got stuck up in the printer out. after that try fixing the papers correctly in it right positions. or don't load much papers again. if you know you want to print only a page of work, then try putting on one paper inside.
I hope this works for you.
May 16, 2011 | Lexmark X2600 InkJet Printer
Keeps showing 900.57 firmware error and the paper gets stuck
Power the printer OFF and ON. Send the same file to the printer, if file has not been released from the print queue then delete all pending print jobs out of print queue.
Disconnect all data cables and power the printer OFF and ON. If the printer returns to READY, Reconnect the data cable and try printing again. If you are getting a paper jam error, please take not the error code and locate the jam. For further assistance, please contact Lexmark Technical Support.
Apr 06, 2011 | Lexmark T652DN MONO LASER PRINTER...
Hi, My hp k550 is blinking at lights 1 and 4. How can I fix this problem please? Thanks
Issue
The power light and resume light is blinking.
Power light and resume light is blinkingc01576793.gif Solution one: Press the resume button
Load paper in the paper tray and press the resume button (c01219285.bmp ).
Try to print the job. If the issue continues, proceed to the next step.
Solution two: Clear the paper jam
Step one: Clear the jam from the back and top of the product
  1. Remove any paper loaded in the output tray.
  2. Turn off the product.
  3. Push the button on either side of the rear access panel or duplex unit and remove it. Figure 7: Removing the rear access doorc01576794.jpg
  4. Locate any jammed paper inside the product and pull it out towards you.
  5. If there is no jam, push the latch on the top of the duplex and lower its cover. Figure 8: Lower the product coverc01576795.jpg
  6. If the jam is there, carefully remove any jammed paper and close the cover.
  7. Replace the rear access panel or duplex unit.
  8. Open the top cover.
  9. Check for and remove any jammed paper by gently pulling it out.
  10. Make sure that there are no scraps of paper stuck between the rollers.
  11. Close the top cover, turn on the product, and resend the print job.
Try to print the job again. If the issue continues, proceed to the next step.
Step three: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Cause
The product might be out of paper or there might be a paper jam.
Feb 28, 2011 | Office Equipment & Supplies
There's a paper jam in OKI B2400n printer. the manual says to take out the ink cartridge and the jammed paper could be pulled out. Well, the paper is tight and I can't pull it out. What can I loosen or...
You will have to pull hard and evenly to remove the paper. Often, the toner has built up on the fuser rollers, and the paper is actually stuck to the rollers. In that case, you will not be able to get all the paper out, it won't do you any good to remove the paper anyway, because the paper will just jam and stick again. Those rollers will need to be replaced. That is a pretty big, technical job.
Oct 18, 2010 | OKI Office Equipment & Supplies
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer says Paper Jam but it is not
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
Sep 22, 2009 | HP Deskjet D2360 InkJet Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I keep getting a paper jam every time I try to print photos? How do you get the paper out of the back without ripping?
Id there trap door on the back with a tab on it. If it does opuch the tab in and pull the door open and out this is th best way to remove jams. If not there may be a way in the fron f the printer to pull it out pull it jentally so it will not rip and mak it harder to get the remaning piceses out.
May 05, 2009 | Samsung CLX 3160fn All-In-One Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
113 people viewed this question
old marine
old marine
