Question about LG Electronic Window Air Conditioner
How to convert window ac to split ac
I want to convert my window air conditioner to split air conditioner is it possible? can any one suggest how i should go about. . .
3 Suggested Answers
  • 3 Answers
SOURCE: i have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Posted on Jun 25, 2009
Myminisplit
  • 11 Answers
SOURCE: LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
Posted on May 21, 2010
Is Portable AC worth the buy ?
split system is better option. more expensive but more dependable.
Sep 08, 2015 | Heating & Cooling
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
My LG 1.5 ton split ac shows F10 error can u pls suggest wht to be done
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Bulance AC Cleaning Repair Services
May 06, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Blover weal in my ac unit LG dosnt runing , during ac run in cooling mode, whot is problem ?
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 28, 2010 | LG LS-L1210CL Mini Split Air Conditioner
The best pressure of gas in a split ac in
65 psi is the ideal pressure remember its not exceede from this pressure.
and it is valid for all season
Jun 05, 2010 | LG LSC121PMA Split System Air Conditioner
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
New electrical wiring for split ac
Connect the two wire from the t-stat to the coil on condenser and take the 240 volt and connect it to the contactor.
Feb 23, 2009 | Fedders AED24E7F Wall/Window Air...
LG Electronic Window Air Conditioner Logo
18 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
