Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
When i change my drive belt it gets shreded on start up
    Problem Solver:
  • 22 Answers
THE BELT TRANSMITS THE MOTOR POWER TO THE DRIVE MECHANISM TO MOVE ALONG THE TRACK TO LIFT THE DOOR. EITHER THE MECHANISM IS JAMMED OR THE DOOR SPRINGS ARE BROKEN SO THERE IS TOO MUCH FORCE ON THE BELT AND IT SHREDS.. TRY LIFTING THE DOOR IT SHOULD GO UP EASILY IF THE SPRINGS WORK. IF THE DOOR IS VERY HEAVY THEN THE SPRINGS NEED FIXING
Posted on May 08, 2014
    New Friend:
  • 25 Answers
Sounds like either the belt is not tight or more likely your door balance is heavy ie fatigued/broken springs or its hung up somewhere.
What causes serpentine belt to shred?
heat age miles oil contamination. improper routing. bad tensioner most likely
Apr 17, 2015 | Cars & Trucks
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
Vovo c70 timmeing belt diagram
dear sir you must take back car and demand a new teninor and idler this will caus belt to ride over to one side and cause shreded belt and belt will come off at dealer or shop it went back to same man and he cant se problem do to belt off if he was to start and let run for 15 min. and in that time start and start and stop motor 3 or 4 times he would see that the belt is walking over to one side do to bearing going out or he may have put washer behind a part but i would go with the idler and tensinor
Sep 07, 2011 | 2002 Volvo C70
2000 ford zx2 shreded serpentine belt in half while driving after replacing car wont start
More detail would be helpful. By not start, that could mean the engine rotates but won't start or you turn the key and nothing happens.
Since you do have a 2000 model I can tell you that they had issues in that model year with crank walk. The thrust bearing in some engines was too small and would allow the crank the move side-to-side (transversely) in the block. Some symptoms included knocking, engine dying on turns, timing or serpentine belt failure....
Oct 12, 2010 | 2002 Ford ZX2
Timming belt shreded, do you think hurt anythig ,head valves ect. how mutch to fix 1997mazda millenia
Hi More than likely, most of the Mazda range are identified as an interference, in other words when the timing belt breaks or slips the pistons will hit the valves, my advice change the belt and then compression test the cylinders before removing the head just in case god smiled on you,
Mar 13, 2010 | 1997 Mazda Millenia
My jeep keeps shreding serpentine belt
Either the tensioner is defective and needs replacing, or the pulleys are out of alignment. I would suspect the tensioner pulley is bad. I am assuming you are installing the correct belt.
Oct 27, 2009 | 1995 Jeep Grand Cherokee
2000 Plymouth grand voyager ticking issue
YOU NEED TO ISOLATE TICK TO FRONT OR REAR BANK OF ENGINE..A MECHANIC'S STETHOSCOPE CAN HELP YOU ISOLATE..THEN REMOVE FRONT OR REAR VALVE COVER AND PUSH ON EACH ROCKER ARM..IF A LASH ADJUSTER(LIFTER)IS BAD,IT WILL BE SOFT OR COMPRESS WHEN YOU PUSH ON IT..LIFTERS ARE IN ROCKER ARMS ON A 3.0L AND IN BLOCK ON 3.3 AND 3.8L ENGINES
Jun 21, 2009 | 2000 Plymouth Voyager
Motor turns over but wont start
Does the distributor turn? Some of the old serpentine belt might have got into the timing belt and broke it.
Apr 08, 2009 | 1996 Dodge Caravan
Drive belt direction
found the answer to my problem with my local motor parts suplier
Jan 26, 2009 | 1998 Audi A4
Kenmore 80 series washer
If the motor is starting? it will be just a belt replacement belts range 15-40ish
Jan 03, 2008 | Kenmore 24032\24036 Top Load Washer
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
60 people viewed this question
Top Chamberlain Building Materials Experts
Terry Smith
Level 1 Expert
Joseph Hoffmann
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
