Question about Sewing Machines
How can I fix a brother PR-600 thats says main motor encoder signal error?
5 Suggested Answers
SOURCE: Brother pro 600 embrodiery machine
You may have a bent bar inside the machine (big trouble), needle error is easy it is just to wind the big nob at the back of the machine, make sure you are on the correct needle when you move it, on mine it is a little stiff, just do it slowly. The engineer just bent my bar back into shape, that was 1yrs ago. Good luck have fun :-)
Karen (wytchstitch)
Posted on Jan 04, 2009
  • 52 Answers
SOURCE: brother pr 600 has x axis possition error message.
In most cases customer were emb. bags when or after you get this error message, there is a sensor under the x-axis; horizontal arm; that gets hit and breaks you can try to get a dealer to sell you the sensor and repalce it yourself its really easy, one screw on the side of the x-axis cover and it lifts and slides off and one screw for the sensor plus two flexible flat cables plug into it
Posted on Jul 07, 2009
SOURCE: Brother PR-600...does anyone know if it's a major
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Posted on Mar 01, 2010
  • 1564 Answers
SOURCE: Brother pr-600 screen not responding
See if you can discover how to reset the machine. Typically it is a combination of buttons pressed either simultaneously or in order as the machine is starting.
Posted on Dec 10, 2012
What does Main Motor Rotate Error message means on a Brother PR650E
Hi if the main shaft is turning the fault is a faulty encoder if it is not turning faulty drive belt or main motor. All these items are under the machines covers.
Feb 18, 2015 | Brother Sewing Machines
My pr 600 freezes
You might have Thread particles build up. Puchase canned Air for electronis and use it on a regular basic to clean your bobbin case area. Also when you change threads color always clip your thread near the spool and pull your thread out from the bottom near your needle. When you pull your thread through the top little pieces of the thread break of and fall into the chamber of your embroidery machine .
Mar 05, 2014 | Bernina Bernette Deco 600
Getting main motor error on brother pr-1000
it would be good to have the machine checked to see if it's a wiring problem or the motor is going bad.
Sep 27, 2013 | Brother Sewing Machines
Dec 10, 2012 | Sewing Machines
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
Nov 04, 2009 | Brother Sewing Machines
Brother pr 600 has x axis possition error message.
May 05, 2009 | Husqvarna Designer I
Wiper error occuring between thread sequence.
wiper error can come from the needle threader not working right, the cutter not working right or the picker not working right, i would recommend taking this to a dealer for service because setting the picker is easy but you have to be in the service program of the machine
Apr 27, 2009 | Husqvarna Designer I
Karen (wytchstitch)
Oct 21, 2008 | Husqvarna Designer I
Needle securing screw
My PR600II error message main rotate error. what can i do to fix it
Nov 29, 2007 | Brother Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
