Question about Braun Food Processors
Disc carrier can't be removed.
The disc carrier (with shredding insert in place) has become fixed on the shaft and the working bowl cannot be removed. Motor works OK but I can't get the lid off. I have tried a few drops of olive oil into the shaft - no help. Any suggestions please?
    Problem Solver:
  • 6 Answers
Check your manual first. If you don't find the answer to your problem, contact the manufacturer for instructions. You should have an 800 # to call with your problem or go online to ask your question.
Hope this helps.
Posted on May 08, 2014
SOURCE: I am unable to remove the disc stem
There is no mechanism to lock the stem onto the base of the KFP750. It's just held on by gravity, so you're not missing anything simple!
It's possible that the soap dust got in there and glued in on. Take a blow dryer or very hot rag (use tongs!) to the stem to see if you can soften the soap, then pull up the stem.
Posted on Jan 06, 2009
milten1
  • 1304 Answers
SOURCE: I broke my FP1445-10 Shred Disc on my Black & Decker
F905801440000000 SLICE/SHRED DISC call 1-866-925-PART
10.00 bucks
have a great day
Posted on Oct 08, 2009
SOURCE: GE 4 Speed Food Processor Replacement Parts
need additional blades for the ge food processor
Posted on Apr 08, 2010
SOURCE: I need a replacement part for my Braun
I have the same problem - need to replace disc carrier for my old Multipractic Plus food processor. Did you ever find one?
Posted on Sep 12, 2010
gvince4
  • 31 Answers
SOURCE: Hello, I have a Breville
Call the Toll Free Phone Number: 1-866-BREVILLE (1-866-273-8455) 8:30AM to 5PM Eastern Time.
OrEmail: AskUs@Breville.ca
Posted on Nov 26, 2010
How do I remove shredding disc from center of plastic bowl. 1st time in 37 yrs it is entirely stuck.
wow didn't know they lasted that long . but get some really good gloves and try turning the opposite direction that they cut and pull outward toward you .
Feb 14, 2015 | Food Processors
I have a LaMachine (72 ounce Bowl) that is approx. 38 yrs old and still in Great Condition but I am in need of the Reversible Slicing/shredding Disc. Where can I purchase this item?
Check where model # is located for name of company. Then check online with that company. If u have a Kitchen/Cooking shop near by u may be able to order thru them.
Sep 12, 2010 | Moulinex DG6 Food Processor
Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Aug 31, 2009 | Food Processors
10.00 bucks
have a great day
Aug 24, 2009 | Black & Decker FP1445 Food Processor
Light comes on but won't pulse or turn "on."
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Aug 03, 2009 | KitchenAid Food Processors
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
My disc stem is stuck and will not come out.
Without careful use and care, there is a possibility that the disc stem can become fused with the motor shaft. If excess pressure is being applied to the slicing or shredding disc, this can cause immense friction and cause the plastic disc stem to "weld" onto the motor base itself.
I would suggest calling Kitchenaid Customer Service to see what options are available.
Their toll-free number is: 1-800-541-6390.
Jun 06, 2009 | KitchenAid KFP740 Food Processor
Missing blade
try this link
http://www.householdappliance.com/food_processor_parts.html
good luck...Lee Anne
May 27, 2009 | Sunbeam 4817 Oskar Food Processor
Braun multipractic food processor model 4259.. Need the insert carrier. Spindle post from bottom to flange is 1 3/4 inches. Where might I find one? What kind of plastic is it made from? Would an epoxy or...
The disc carrier you're looking for is Part No 7002058 (the number may be stamped somewhere on the holder itself). It's like a circular/figure 8 kinda looking thing on a shaft. If you're in Australia I'll be able to help get spares.
Don't recommend using glue to repair due to stress breaking it again, and for food safety issues.
Mar 30, 2009 | Food Processors
Food Processors Logo
51 people viewed this question
Top Braun Food Processors Experts
eyecam
Ashutosh Khandelwal
Level 1 Expert
Are you a Braun Food Processor Expert? Answer questions, earn points and help others
