Question about Toshiba TEC B-SX4 Thermal Label Printer
Labels not moving forward enough
When printing a run of labels the label does not move forward enough and the print begin to overun the labes
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Check that you have activated tyhe right detection and not using continuous material in the driver. You should use Transmissive or blackmark depending on your labels.
Posted on Jun 10, 2014
checkitright
  • 1362 Answers
SOURCE: skipping 1 mm (regular intervals) while printing labels
1-try to recalibrate labels
2-make sure the label size is correct in the settings:
here is the link for the driver. :
http://barcode.toshibatec.co.jp/Eng/download1.html
Posted on Nov 09, 2007
  • 254 Answers
SOURCE: NEED TO CALIBRATE MY SX4
Switch the printer on with the buttons feed and pause pressed.Press feed to display Sensor adjust. Press pause until transmissive is displayed. With the liner in the cells press on restart until a star is displayed next to the value (around 4.7V) press Pause the calibration is finished. In my opinion, you should check the size of your label and the distance between the labels (label gap) and also check that you have selected the correct detection (Transmissive for gap or relective for black mark)
Posted on Sep 02, 2009
  • 254 Answers
SOURCE: TEC B472 won't print full qty of labels
What is the software used?
Normally the printer will decrement or increment its counters when the correct instructions are sent, If it is the pc that sends the labels then your problem is due to the pc.
Otherwise if the count is internal then external electromagnetic noises may cause this sort of phenomenon.
If it's on a parallel port, then your problem may comme from the vibrations of the printer. The init signal on this port is very near to a gnd pin and with the vibrations this causes a reset of the printer.
Last problem may come from a firmware deterioration. All depends cpu either the firmware is Eprom or Rom.
Posted on Sep 03, 2009
  • 254 Answers
SOURCE: The 'eye' won't read the space between the labels,
recalibrate the sensors and check your label lengths and gap size
  • 254 Answers
SOURCE: Label over run
Check the size of the label in your codes or driver.
The length must be correct or else you cannot use it correctly.
You must may be recallibrate the sensors
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Print on ribbon is 1/2 off label
check the driver (length and with) from the driver if is the same that the size from the labes that you have.print test page (print full label?) if not work, Reset to Factory Defult (Turn On with FEED and CANCEL buttons pressed, and relese after 5 seconds.
Oct 31, 2010 | Zebra S4M Thermal Label Printer
I just purchased new cartridges, but there's no print on the labe
It was the batteries. I bought new ones and it works now. Good advice. Thanks.
Nov 18, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Label not discharging far enough out of the print head
Hi
Can you tell what the printer is and what the material spec is?
Regards
Bob
Jan 11, 2009 | Zebra 110PAX4 Thermal Label Printer Print...
Printing CD labels , can not get it to line up stright.
I have the exact problem with my HP Deskjet D2360...Done all adjustments, doesn't print in the outline of the label...help
Nov 09, 2008 | HP PSC 1510 All-In-One InkJet Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra 110xi plus not printer strainght across label
* do full manual calibration
* reduce the print speed & try
* set back feed as before instead of default
* try with little big labes
Jul 28, 2008 | Zebra 110Xi III Plus Thermal Printer
Out of order printing..
You did not adjust the label sensor.(media sensor)
1- for labels with a noth move towards the notch
2-for labels with a space between them move towards middle.
look at page 28 (zoom 400%)
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Oct 16, 2007 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
89 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
