Question about Kohler SAN RAPHAEL 1PC LT TOILET K-3393-Y2
Installing san rafael toilet on non-san rafael floor fitting
Have an older san Rafael that is leaking and I found that the fitting on the concrete floor is not san rafael
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Get the adapter $35
Posted on Apr 16, 2014
    Sergeant:
  • 264 Answers
Hi I'm Peter, I am not sure what fitting you are talking about do you mean the flange that is mounted in the hole in the floor that the toilet bolts to? here is a link that has all the parts for your model . I have not run into a different type mount unless the hole was too close to a wall or something and you needed a 45 degree offset flange. I called a couple of friends that work where they sell the Sad Rafael and they said it uses the normal flange and seal. Here is a site that has a picture break down of your toilet and the prices. If you do not see what you need I am positive they will be able to clarify your need and expedite the part. Hope this helps and you get it in before you need it. LOL
2 Suggested Answers
  • 83 Answers
SOURCE: how do i adjust the
should be a little screw on top of flush valve...or just bend ball arm alittle till the water level is met
Posted on Nov 22, 2010
What best flooring for kitchen large dogs
Better Ceramic Floor Tiles where can easily clean.
Apr 13, 2015 | Building Materials
I would like too see a video on how too install a toilet
Hi mary
Here is one video and a webpage that may help you a lot on the installation of your toilet.
You mentioned that you wanted to move the toilet in the same room, that will only be possible if you have a wooden floor.
Otherwise if you have a concrete floor, it can be done, but it will be really expensive to move the toilet to a different location in the same room. The concrete floor would have to have a hole bored thru it and the dirt removed under the house to get to install the necessary pipes...really expensive.
Removing and reinstall the toilet: http://www.youtube.com/watch?v=Y_hVZ3rPzm4
Webpage for plumbing in your toilet.
http://homeguides.sfgate.com/plumb-toilet-start-pipe-34476.html
Please take time to rate me
Bud
Nov 02, 2012 | Home
Zip code pasay city
Location ZIP Code Phone Area Code
Domestic Airport P.O.
1301
Manila Bay Reclamation
1308
Pasay City CPO - Malibay
1300
PICC Reclamation Area
1307
San Isidro
1306
2 San Jose 1305 2
San Rafael
1302
San Roque
1303
Sta. Clara
1304
Villamor Airbase
1309
Aug 11, 2011 | Computers & Internet
How do i adjust the water level in my San Rafael It is too high and going over the top of the tube
Nov 21, 2010 | Kohler Toilet - One Piece with Ingenium...
I'm trying to install my Neptune Catania toilet and my flange is on the surface of my floor. Problem is the toilet doesn't sit all the way down on the floor, about 1/8 to 3/16" away. Second problem the...
If the toilet does not sit fully on the floor then it will need to be shimmed. Use plastic, fiberglass or composite shims to level the toilet. Wood shims will rot. Caulk around the front and sides of the toilet to hide the shims. Do not caulk around the back as if the toilet leaks you will not be able to tell if it is fully caulked. Epoxying the flange will work however you will want to check with local building codes to ensure this is compliant.
Jul 15, 2010 | Neptune FB1635 Catania Toilet
Dead Netgear jgs516dead Netgear jgs516 . No lights. the inside power supply outputs 1.5V instead on 5v. Delta PS # ADP-40VP Where do I buy a replacement? I am in San Rafael, CA
Well, I believe the product you have carries life time warranty with NETGEAR. Hence, you can get it replaced from NETGEAR. Please log a support case with netgear at http://my.netgear.com
Regards
Anand Gupta
Apr 20, 2010 | SMC Netgear 16Port Gigabit Ethernet Switch...
I have a pure digital camcorder model # 225 and I see a slot on top of the camera and I'am wondering if this is for any sd card ? can you let me know about this , please thankyou , Rafael
I have a pure digital camcorder2_bing.gif model # 225 and I see a slot on top of the camera and I'am wondering if this is for any sd card2_bing.gif ? can you let me know about this , please thankyou , Rafael
Feb 05, 2010 | Pure Digital Flip Video Camcorder
No toilet flange
Go to a hardware outlet(Lowe's, HomeDepot, etc.) and ask for a commode drain extension that can be placed over the existing and bring it up to the level of your floor. I also like the wax rings with the cup molded in. These can be doubled up also but not as reliable as the extension.
Eric
Dec 30, 2009 | Jacuzzi BK37959 White Era?? Two-Piece...
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Kohler SAN RAPHAEL 1PC LT TOILET K-3393-Y2 Logo
77 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
