Question about GPS
My garmin nuvi 50 not charging at all
I tried AC wall charger, cigarette lighter in car and also usb cable to laptop. It still won't charge
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Get a small bright flashlight, and a magnifying glass if you have on and look into the charging port on the back of your nuvi.
you should see 4-6 small gold strips on a bar.if they look corroded you may need a new unit, if they are dirty find a tooth pick and some rubbing alcohol and gently clean off the contacts,
if that does not fix the problem , then your charging port is bad on the nuvi.
Posted on Apr 16, 2014
Testimonial: "Thanks Joey for your time and reply. Tried this. But not luck. My mini usb charging port actually looks clean. My unit is only a year plus old. Any way to replace the charging port? Would replacing the battery be a good idea?"
  • 3 more comments
  • Joey Bain Apr 16, 2014
    Okay so it has a good looking mini USB port, next the battery replacement is a good idea.
    Add a CommentYou can get the new battery from Newpower99.com and the special tool to split the case. Once you have received the new battery, you will remove the 4 screws on the back of your garmin, then carefully split the case, remove the two screws holding the circuit board to the case, the unplug the existing battery, if the battery adhesive is too strong and the battery is stuck barely warm it up with a hair dryer, then replace the battery and put your unit back together, and power your unit on
  • rahadz1 Apr 16, 2014
    Thanks buddy. Might have to try that as Garmin customer support has been completely useless in giving any type of troubleshooting advice
    Not a problem,, they never will be much help on any of their "not the newest" models. And that's why we're here. Good luck buddy
  • rahadz1 May 09, 2014
    Hi Joey, I replaced my battery. The good sign is it is charging now but the bad news is only intermittently. I try to fiddle with the cable around charging port. Seems like is loses its contact and goes offline again and again. It keeps happening. I unscrewed the unit and made the circuit secure. But that didnt fix the problem :(
SOURCE: garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Posted on Feb 12, 2009
  • 4090 Answers
SOURCE: Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Posted on Jun 30, 2009
SOURCE: Garmin Nuvi 255w won't start up. tries loading
You should try to manually delete the maps (after a backup ) on the device , power cycle and retry sending the maps from MapSource or the Software CD from the manufacturer. The map is a single folder onto the device (eg. gmapsupp.img)
Posted on May 26, 2010
  • 1043 Answers
SOURCE: garmin nuvi 260w is not charging with car charger
You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
Posted on May 29, 2010
  • 1111 Answers
SOURCE: Garmin Nuvi 750 car cradle/charger does not charge
Hi tbrick
if you dont have the original charger, the 750 take a special car charger because of the traffic feature...it has a flat end about 3/4" to 1" long that fits in the cradle, but you can use a garmin usb charger, you just wont be able to use the traffic feature.
if thats a little confusing ( i tend to do that) i try and explain it another way.
if you think you need or want one of those chargers, just post back to me.
bill
Posted on Nov 01, 2010
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
How do I recharge the battery on my Garmin Nuvi 255WT? I would also like to know how to update my Garmin?
Recharging the battery is done by connecting the nuvi to a vehicle power cable in the car through the vehicle power accessory outlet or cigarette lighter.
The unit can also be charged via a powered USB port off your computer via the USB power/data cable or an AC power adapter through the USB power/data cable.
Aug 15, 2011 | Garmin nuvi 255W GPS Receiver
I dont know how to charge my GARMIN nuvi 1200 with the usb cable
There are 3 ways to charge your garmin nuvi 1200 as follows;
  1. Connect your satnav to a computer with the mini USB cable. Plug the narrow end into the satnav, where the power cable goes, and the other end into the USB port of your computer. Both computer and satnav must be turned on. It will take about 8 hours to charge like this.
  2. Connect your satnav to your car charger and plug the charger into the cigarette lighter socket of your car. It will take about 4 hours to charge.
  3. You can get an optional mains charger which also takes 4 hours to charge the satnav.
May 23, 2011 | GPS
Charging my nuvi 250 with a USB cable from my apple
When the GPS is hooked up to charge the battery it will say charging,try turning it on when hooked up and see if it is in fact charging,otherwise have you thought of purchasing a wall charger,I got mine on Ebay,very reasonable and works great,saves the hassle of hooking up to my comuter.Hope this helps with the problem.
Sep 29, 2009 | Garmin nuvi 255W GPS Receiver
Charging the battery in Nuvi 760
1) Check the cigarette lighter is working by plugging in the lighter unit and see if it gets hot. If it doesn't then it is possible the fuse has blown.
2) You can plug the unit into a PC using the USB cable and if there is a fault you will get a message on the screen about 'USB over-current' but it shouldn't damage the computer.
If it runs/charges using the PC and (1) is OK then you may have a problem with the cigarette lighter - cradle cable or a problem with the cradle itself.
HTH
Peter
Jan 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
  1. Connect the nuvi to the suction cup mount and the vehicle power cable.
  2. Connect the USB cable to the nuvi and the computer. The computer will charge the nuvi as long as the computer is on. However, the unit will be in Mass Storage Mode and normal operation is not possible.
  3. Connect the AC power cable and the nuvi to a wall outlet.
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Oct 11, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Don't work with the cigarette lighter connector
Check if you are able to charge other devices via the cigarette lighter such as a cellphone or try to use the lighter if the light does not get as hot as normal then that means that there is not enough power. If that looks ok then try another cable charger for your Nuvi
Aug 09, 2008 | Garmin 010-00358-00 GPS Receiver
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
50 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
