Question about Garden
Cant get the caseing off the karcher?
Karcher k2 900
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Have you removed all stickers?
Posted on Apr 21, 2014
How do I find fuse on karcher hd650sx
Should be situated under the plastic case by where the wires enter the case.
Aug 19, 2016 | Karcher Garden
I have a karcher k2.65m pressure washer which is leaking from inside after removing the outside covers i could not see how to separate the black plastic case to get into the pump etc any ideas ??
A picture might help.
You could always find the part and number here http://www.ereplacementparts.com/karcher-226m-16016020-pressure-washer-parts-c-33388_33389_33977.html Karcher 2 26M 16016020 Pressure Washer Parts
Aug 11, 2015 | Karcher Garden
How do I remove casing
there are 2 more screws below the snap on base plate if you have further problems go to espares site look up karcher spares put in inlet elbow and there is a video showing how to split casing it is quite easy when youve seen this good luck
Jan 16, 2015 | Karcher Garden
Karcher k2 900
You tube, karcher k2 900 take apart, This is the easiest way to do it,
Apr 16, 2014 | Garden
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
http://www.sparesgiant.com/cleaning-equipment/pressure-washers/karcher/k-series-parts/k2-range/k2-36m16724300/
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
I purchase a new water intake fitting for my karcher 395 and can not figure out how to swap it with the broken fitting
I think there are 4 bolts you have to take out, they are at the end of the pump,, but i think the intake and output are on that part,,,also if you ever cant find a karcher pump a king will fit
Jul 28, 2010 | Karcher 2500 PSI Pressure Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
My Karcher is leaking from the motor I think. Is it fixable? It's a KB 5050
My Karcher K 3.99 is leaking and dropped pressure. is it fixable (not filter)
Apr 04, 2010 | Karcher K DS 5500 Vacuum
How do you replace the pressure loading valves
if it is a karcher machine you will need to remove the pump, and the valves need to be removed with a set of valve pullers, karcher sell the special tool needed for this, you cant remove the inset types any other way but with the tool,
any questions just ask away
Feb 24, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
