Question about Panasonic NN-S569BA Microwave Oven
Microwave shut off
After pressing start, microwave frequently shuts off and resets (displays "88.88").
  • Official Brand Answer
  • 350 Answers
At this time we recommend you test the microwave on a different power outlet. If the problem persists, please use the below link to locate an authorized service center.
Welcome to Panasonic Online Repair
Posted on Apr 16, 2014
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
My microwave keeps shutting down and i have to
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, a repeat of your symptoms, as well as the answers to these questions:
When it shuts down, is there anything still on the display?
When it shuts down, does the light still come on when you open the door?
When it shuts down, do you still hear any beeps when you press a pad on the keypad?
Also let us know it if fails while in use or while idle.
Nov 28, 2009 | Magic Chef Microwave Ovens
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Reset shows on display of my GE space saver microwave oven
change the board that has the reset on the display board it is bad
Mar 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
Mar 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Flashing 88:88 display - no keypad response - no light
I’ve read through your problem in an attempt to find a solution to my own similar issue with my microwave oven. Other solutions (like unplug appliance overnight and reconnect to power source the next morning) did not work for my appliance.
Just as I was about to call it quits and go out to purchase a new microwave; I gave it one last try. This time, instead of pressing any and every single button on the keypad, I decided to press BOTH the "Stop/Clear" AND "Start" buttons AT THE SAME TIME. . . . . Voilà! This worked for me, but sadly, it's now May-2008 and I'm pretty sure you're own microwave is long gone since your posting appears to have been quite some time ago. Well, hopefully others that stumble through these pages with similar issues may find some assistance with my approach. Oh, and btw. . .I got this idea (which worked) from remembering the instructions on how to reset my cellphone. Many thanks, ~paul
Sep 13, 2007 | Sharp R-220HW Microwave Oven
Panasonic NN-S569BA Microwave Oven Logo
138 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
