Question about Whirlpool Washing Machines
Whirlpool Duet Hello my name is Eric and I have a Whirlpool Duet Model #wfw9150ww02 s#hl12557435. I washed a heavy blanket the other day and when i came back it was beeping and the wash LED wash flashing and the door was locked. Was LED blinks 3 times then 2 times, beeps 3 times rapidly. The machine currently will not go into any cycle, when started goes right to wash blinking 3 then 2. Tried unplugging and also a new CCU board. Any otheer suggestions? I am a mechanical guy and can check reading if needed
Whirlpool Cabrio Washer mod WTW7600XWO. It will not cycle it ha two wet heavy blanket s in it.
there is a possibility that the circuit board has been dislodged by the rocking of the machine unplug the machine and check inside for loose or dislodged cables eric
Dec 27, 2017 | Whirlpool Washing Machines
My blanket stopped working. How do I replace under warranty?
Hello, Eric -
You will need to contact the blanket manufacturer. Only you know that. If you need help in finding the manufacturer's web site, you can Edit your question and add the name of the manufacturer. You can probably find the name on a tag on the blanket.
Dec 25, 2017 | Heating & Cooling
Wfw9150ww02
any error message or flashing light?
Feb 28, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
My front load washer had a f09 then e01 code come up today. I think something is clogging somewhere
blankets can be very heavy and ball up on one side of the washer during spin cycle and cause the washer to shut down do to inballance... remove blankets & spread them ou if the are twisted up also mabe leave one of them out and rinse separatly..
Jul 09, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will not spin all water out of a blanket
The number one cause of all spinning/draining problems with the Duet washer is a clogged filter screen on the drain pump, I have written this tip that shows how to check/clean that filter.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Just bought the Whirlpool duet tumbler fresh model # wfw9150ww02. Washer will not start. When I press start the add garment light comes on. Then the door lock comes on. Did trouble shooting as...
Take the back off of the washer...99% of the time it is the wiring that is secured with very tight zip ties. Most of the time it is one of the black wires that has been split in half and is losing contact. Once you have taken the zip ties off fix the wiring and then use electrical tape to join the wire instead of replacing zip ties.
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell in washer and clothes
run a wash with no clothes and hot water. put bleach in the detergent and bleach dispensers. when done washing for the day wipe the boot with a clean cloth and leave the door open, especially on warm humid days.
Eric
Jul 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer spins but cloths still damp after full cycle stop.
I have the same washer and it will do this if I have put a load of clothing that is not even in weight for example I washed sheets with a heavy blanket and I then had to run the Drain Spin cycle. Hope this help
Sep 06, 2009 | Washing Machines
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
