Question about JVC Televison & Video
I have a JVC AV 27530 television and I need to be sure that the setting is on Antenna and not on Cable. How do I do that? I have been unable to find a manual.
    Top Expert:
  • JVC Master
  • 74,136 Answers
Http://dutchmen.com/image/data/documents/parts/JVC_TV_AV-27530_&_AV-27WR25.pdf
Download the user manual to this set by the above link. It has all details.
google.com/+GopakumarGopalan
Posted on Apr 16, 2014
  • 556 Answers
SOURCE: Universal code for JVC-AV 27230
www.remotes.com
please try this web site you will get the solution
good luck.
Posted on Oct 17, 2007
  • 3 Answers
SOURCE: Jvc av 27530
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Posted on May 15, 2008
  • 10 Answers
SOURCE: can't find code for JVC AV-27220 tv remote
Hi Please follow this link and u can get the full manual to fix the problem.
Please review and say if it helped thanx
<a href="http://www.nodevice.com/manual/newmans/AV-27220pdf/get16984.html">Download JVC AV-27220 Service Manual</a>
Posted on Apr 19, 2009
  • 9 Answers
SOURCE: Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Posted on Jun 16, 2009
SOURCE: Picture on tv JVC 27" AV-27530 is getting to dark
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Posted on Jul 11, 2010
My tv jvc av 27530 has ablue screen and un able to operate by remote or manually so could you help me please?
many of the late model tvs with a crt (picture tube) would go to a blue screen when there is not signal from the cable or antenna so you don't get the irritating white noise and black and white dots running all over the screen, (called the raster), so probably you aren't getting a signal to the tuner. check your connection from the cable/antenna.
Sep 25, 2014 | JVC AV-27530 27" TV
JVC TV Blue screen No remote
To select the source you must have its remote control. There is no TV/AV source select button at the front panel of this TV.
Jan 04, 2013 | JVC AV-27530 27" TV
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
Jun 11, 2010 | JVC AV-27530 27" TV
I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Apr 08, 2009 | JVC AV-27530 27" TV
Televion was purchased in 2002 picture was sharp
Need more information.
Are you connected to an antenna?
Did the stations in your area go digital? (DTV converter required)
Mar 02, 2009 | JVC AV-27530 27" TV
How do I get the dialogue removed from my TV screen?
Hi and welcome to FixYa,
Offhand, it would appear that the 'Closed Caption' has been enabled in your TV. This can de disabled in the MENU/Settings. A more detailed procedure would be available in the owner's manual or pls post back to confirm if your TV is a JVC AV-27530.
Good luck and thank you for using FixYa.
Feb 20, 2009 | JVC AV-27530 27" TV
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
TV Value
under $100.00
Aug 04, 2008 | JVC AV-27530 27" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Televison & Video Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
