Question about Garden
How do I adjust the travel speed on my swisher big mow model ZT2766
    Guru:
  • 145 Answers
Belt slipping? Altering original equipment may cost you a IHT transmission. 500 bucks each
Posted on Apr 19, 2014
2 Suggested Answers
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
Engine runs on my swisher 2560 but will not move, stopped while mowing
Drive belt may have broken or idler pulley could have malfunctioned or drive belt could have just came off alignment.
Sep 10, 2017 | Swisher Garden
Swisher xzt 60.. while mowing grass pushing the arms forward the blades slow way down.. how can i fix this issue? I just put new deck and engine belts on..
Swisher is proprietary in the service arena for information. The most common cause of the issue that you are describing is belt slippage. This could be due to oversize belt length. improper tension, loose pulleys etc. Also when you look at an area that you have mowed after one day, if the tips of the grass are yellow, the blade is not sharp enough.
Jun 21, 2014 | Garden
How do I adjust the travel speed on one side of my swisher at2766
The slower side may be out of adjustment, low on fluid, low air pressure in the tire, linkage set incorrectly
Apr 16, 2014 | Garden
I need the carburator bolt sizes for a swisher trim and mow 650 series model st65022q
you can best find this from the manual or the manufacturers website
Sep 08, 2013 | Briggs & Stratton Garden
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Left side of mower fell into hole while mowing - blade does not rotate smoothly and when blade spinning at full speed makes loud rattling did i bend one of the prop shafts ?
yes, it is bent, the equilibrium has been thrown off balance, unless you can hammer it back straight, I suggest replacing the blade with a new one or have a machine shop press your old blade back into shape
Aug 15, 2009 | Swisher Finishing Trailmower - 44cutting...
My swisher pull behind was working fine and I was
take the cover off above the ignition switch ckeck 4 loose wires if nothing is found wrong jump it at the selinoid if it starts go to the nearest perts store and buy a selinoid for an ole ford truck transfer wire exact and it should wrk fine
May 03, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
