Venting My hairdryer is not venting properly at the back so it keeps on cutting out is there a way to get into the back and remove the dust???
  • 3 Answers
  1. Rory, normally you shouldn't have to disassembly anything to solve this problem. Clean the screen where the air is drawn in at the rear of the hair dryer with a small brush, like an old toothbrush. If you still have a problem, be sure the dryer is unplugged, remove any nozzles attached to the discharge end and then remove any screws you can find that will allow the case to be split into the left and right sides. Some times these screws may be hidden under labels or stickers. There also may be clips holding the case together which may be released by flexing the case or slipping a thin tool into the seam and pushing or twisting to release them.
Posted on Apr 16, 2014
  • 64 Answers
Well if you have some pic or model ...maybe i can tell you how to open it..
Regards,
Jovan.
2002 SPORTSTER KEEPS SHUTTING OFF.
Hi, Robert and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Engine cutting out
http://www.carlsalter.com/pdfs/Harley%20Davidson%20%20Sportster%201986-2003%20Service%20Manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak with me personally absolutely "FREE"
Feb 12, 2017 | 2002 Harley Davidson XL 1200 C Sportster...
Skipping and cutting out after about ten or twelve miles
run fault codes and look for venting problem. canister purge servo /sensor. The fuel tank may not be venting properly and the vacuum in the tank is reducing fuel supply to the injectors. Alternatively check for a collapsed cat converter blocking off the exhaust.
Aug 17, 2013 | Jeep Cars & Trucks
The dryer keeps shutting down. i toke the filtre out and noticed water standing in the rear pan of the dryer. can this be a pump or clog issue?
It sounds like your dryer is not venting properly. Remove the vent hose from the back of the dryer and test the dryer again to see if it shuts down. If it is normal with the vent hose off your vent pipe is plugged.
Jan 02, 2011 | Dryers
My 1995 zzr250 started cutting out on me whilst traveling at about 100km the other day. I slowed down and then it cut out. Managed to start her back up and got her home. Yesterday i gave her a service...
Hi, Carver_c and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Cutting out while riding
2 Wheels View topic zzr250 runs then it doesnt
Kawasaki ZZ R250 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Mar 24, 2017 | 1995 kawasaki ZZR 250
Why does my system cut out at high audio levels?
There is not enough power output coming out of the amplifier and the overload switch kicks off. Sometimes this can be caused by cooling. Check your venting in the back for dust build up. Hope that helps!
Jul 30, 2010 | Yamaha RX-V757 Receiver
Dryer takes long time to dry. usually 2 or 3 cycle. Filycter is cleaned after every cycle. Vent hose is not blocked
This complaint usually is attributed to clogged exhaust venting somewhere. As a process of elimination, remove the exhaust venting from behind the dryer and run your loads. If the dryer dries clothes properly, then your issue is definitely with the exhaust venting (e.g.: inside wall, attic, etc.). If possible, check the entire path of exhaust venting or contact a vent cleaning company.
Apr 14, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer sensor keep opening
Sometimes this will happen if you have blocked venting or the venting is too long of a run. Try doing a load of Towels with the vent off the back of the dryer. If it doesn't open the sensor you know that the venting was the problem.
Dec 22, 2009 | Dryers
Kenmore Dryer Gas 110.73942101
Hi. thanks for the question. The problem you have is with a motor. it gets hot, and cuts off. pull dryer away from wall. clean venting. remove back panel, clean all dust. that will solve your problem thanks the appliance doc
Sep 15, 2008 | Kenmore 73952 Gas Dryer
I have a Fisher Paykel Smartload model DEGX1.It just shut off the other day and will not turn back on..I checked the circuit breaker it was not blown...any suggestions?
It is possible the thermal cut out has tripped. The front panel of the machine would need to be removed, and the cut out manually reset. You will need to find the cause of the tripping. The most likely cause is incorrect venting of the product, check venting before running machine again
Jul 14, 2008 | Dryers
Computers & Internet Logo
David Payne
David Payne
