Question about DeLonghi EAM3400 Espresso Machine
Magnifica EAM3400 dispenses water out of steam wand instead of bewing coffee
When I brew coffee, the beans grind and it sounds like its brewing, but plain water comes out of the steam wand instead of brewing coffee.
4 Suggested Answers
mnwarfield10
  • 452 Answers
SOURCE: The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Posted on Feb 27, 2011
mnwarfield10
  • 452 Answers
SOURCE: Will not brew expresso, the water goes into the
you need it stripped down .. serviced and tested ..
Posted on Feb 28, 2011
taran_2005
  • 10515 Answers
SOURCE: I have a Delonghi Magnifica EAM3200 Expresso and
The hot water dispensers in units such as yours are controlled by solenoids.
The unit then senses that there is something wrong, as there is no water flowing. This tells the control card that the water system needs to be primed/purged of air.
What you will need to do is access the interior of the unit and locate the solenoid that is at fault.
I am sorry but there is no information available to help you do this repair. Apparently DeLonghi wants you to take your unit to one of their authorized service centers so that they can charge you too much to fix it.
There is a consolation though. They will sell you the parts to repair it. You will have to call the 800 number in your owners manual, and know what part it is that you need.
I called them just a few minuets ago and they actually were helpful. But as I am not the owner they would not tell me the part number or anything more than they did have the part in stock. They wouldn't even tell me if it was actually a solenoid. Just that they were familiar with the part and it was in stock. You should not have the same brick wall to knock down as you are the owner of their product.
At this time DeLonghi is still maintaining propriety over the service manuals for this unit if any even exist. There are people like myself that don't need a manual to repair units like your espresso machine. The only thing I would require is access to the repair parts.
Once these units are made obsolete they may release the manuals. It depends on whether they are still bringing in repairs to their authorized centers.
In a nutshell they are not letting go if it makes them money, or they might not even have one. That would depend on if they have guys like me doing the repairs.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 21, 2011
Grinds coffee but does not brew it
Now you know why the price was so good!
Sep 24, 2017 | DeLonghi EAM3400 Espresso Machine
Water dispensing from stem wand instead or brew nozzles
Overfill problem, could be leaky inlet valve or manual fill lever stuck partly on. Franko (ems.coffee768@gmail.com )
Jan 03, 2014 | Saeco Talea Touch Plus Espresso Machine
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
No hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Water ends up in the tray
Have you checked the brew group screen? I am assuming that this is a super automatic machine, and by pressing a button it grinds and brews? If yes then the only other problem would be in the brew unit.
Jul 25, 2009 | DeLonghi EAM3400 Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
No Coffee dispenses
That is exactly what I would've suggested, the brew unit is clogged. remove brew unit and try to blow through the top, if you get through then check the bottom. One of the chambers must be clogged. Another question is the coffee extract wet or dry grounds?
If wet then the block is on the top, if dry it ids on the bottom.
Feb 28, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
46 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
