Question about Chattanooga Triton DTS Chiropractic Table
Goes up but not down
Triton TRT-500 (Serial # 1277)60 Hz and 5 Amp motor, table with a new pedal only goes up but not down?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Is the pedal air or electric? I fit is an air pedal, then one of the bladders inside the motor housing is busted and it will not activate the down switch. If it is an electrical pedal, then there is a problem with power or a bad switch inside the motor housing. If you are not familiar with electrical, I would suggest hiring someone to look at it. Possibly trade out a visit with an electrically inclined patient. If you have more questions, contact me through my website, www.chiropracticconsignment.com.
Posted on Jun 19, 2014
Brake pedal goes to floor
for the pedal to go to the floor there is still air in the brake system. Start again starting from the longest line bleeding each in turn to the shortest line . make sure you have adjusted up the rear brakes before bleeding as every time you press on the pedal the shoes expand right out and when you take your foot off the pedal the shoes go all the way back in. adjust them manually and do not rely on the self adjuster as it only adjusts on wheel movement
Jul 15, 2013 | 2002 Ford Explorer Sport Trac
My Triton 500 feezes at the start up screen. I have tried new batteries, taking the batteries out and placing them back in, and tried the Enter, Esc. and power buttons simultaniously. Still the same...
Triton 500 are junk. I finally just replaced it with a Garmen. They refer to them as "Red Bricks". Contact www.jungleghost.com he repaired my once but it still had issues. His service is great, and will allow you to re-install the operating system. I just got sick of fixing it as it let me down in the field too many time and it got harder and harder to turn on. Sorry for the bad news.
Sep 20, 2011 | Magellan Triton 500 Handheld GPS Receiver
My magellan triton 500 will not fully turn on. It statrts to load the bat goes all the way and then freezes. I can not turn it off either.
You need to reset the magellan triton 500, then it will fully come on and stay on. To reset this type of magellan. What you have to do is to take out the battery and reinstall it back in. That should do the job for you, and if that does not solve the problem, then you have to back up the maps on a computer then format the triton then restore the software and maps back on it. Now am assuring you that will do the job.
Hope this information helped you.
Dec 23, 2010 | Magellan Triton 500 Handheld GPS Receiver
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    I looked up the correct way to wire my JL 13.5W7 1.5. Therefore it said to wire it in parrallel. I understand this will put it at .75 ohm. As I start to turn it up it sounds great, very loud but once the...
    1000/1v2 Class D Monoblock Subwoofer Amplifier Specifications:
      1000/1v2
    Rated Power:
    1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
    THD at Rated Power:
    <0.05% @ 4 ohm
    S/N Ratio:
    >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
    Frequency Response:
    5 Hz - 250 Hz (+0, -1dB)
    Damping Factor:
    >500 @ 4 ohm / 50 Hz
    According to the chart your amp is only stable down to 1.5 Ohms, so running at .75 Ohms the noise you are hearing is the amp clipping (running more power than it can handle at low ohms)
    I would suggest wiring it in series, or you could adjust the gain on the amp until the popping goes away.
    Hope this helps.
    Nov 10, 2010 | Jl Audio 13W7 Car Subwoofer
    My Magellan Triton 500 does not display the correct date or time. Can you help?
    Assuming that you have the latest firmware installed. Do a MENU>>VIEW>>SETTINGS and then using the down arrow to scroll down. The Date and time and language and power settings are out of sight. scrool down and you will see date and time.
    Dec 03, 2009 | Magellan Triton 500 Handheld GPS Receiver
    Installing national geographic topo maps on my magellan triton500
    Two possible answers and they are both dependable on the serial number of the map vs.the serial number of the GPS. The best solution is to use Vantage Point to do the transfer. The second method is to directly load the map to an SD card under the directory MAP_DATA and then place in the GPS. Then do a MENU>>VIEW>>MAPS and activate the map. If the map is missing you do not have it under the MAP_DATA directory. If the map shows a RED "X" then the serial number of the map is not the same as the serial number of the GPS.
    Mar 27, 2009 | Magellan Triton 500 Handheld GPS Receiver
    EPSON PHOTO PC 500 DIGITAL CAMERA
    Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
    The stereo plug is wired to the PC serial port as shown in the following diagram:
    tip ring sleeve +---------------------------------+
    | RxD | Gnd | TxD | 2.5 mm Stero Plug |
    DB9*: pin 2 pin 5 pin 3 +---------------------------------+
    DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
    pin 7 (RTS) to pin 8 (CTS)
    The following table also describes the camera cable's wiring: Camera PC's
    Plug DB9* Signal Name Direction
    - 1 Carrier detect (CD) input to PC
    tip 2 Receive data (RxD) input to PC
    sleeve 3 Transmit data (TxD) output from PC
    - 4 \ Data terminal ready (DTR) output from PC
    ring 5 | Signal ground (Gnd) -
    - 6 / Data set ready (DSR) input to PC
    - 7 \ Request to send (RTS) output from PC
    - 8 / Clear to send (CTS) input to PC
    - 9 Ring indicator (RI) input to PC
    * Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
    Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
    Chattanooga Triton DTS Chiropractic Table Logo
    583 people viewed this question
    Top Chattanooga Medical Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Chattanooga Medical Expert? Answer questions, earn points and help others
