Question about Sharp LC-26D4U 26 in. LCD Television
I cant control the volume on my sharp flat screen tv even with a remote
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
  • 14 Answers
SOURCE: Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Posted on Jul 25, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp Aquous Remote Codes
You can download the manual for the TV. It has all the code for the remote on page 90.
Here's the link:
LC-37G4U | LC-32G4U & AVC System Operation Manual (3900K)
Posted on Mar 31, 2009
welcomejee
  • 10594 Answers
SOURCE: we have a sharp aquos
Unplug tv from wall socket for minute to get it reset, replug back in and turn On tv to check sound output.
If sound problem still not solved then check Sound Menu options and make sure TV Speaker option is On/Enable.
Also connect any receiver/ amplifier at TV Audio Out terminals at rear of tv to confirm sound processor in tv is working or not.
Let me know your findings.
Thanks.
Posted on Oct 09, 2010
SD Tech
  • 14553 Answers
SOURCE: Remote control from Dish tv will not work volume on Coby 32" flat screen
This is not unusual--Dish and other remotes even if program will not have all the functions that may be needed---
Posted on Dec 03, 2012
Need codes for 60 inch sharp l e d flat screen tv. so I can't control my t_v with my x finity remote on and off volume up and down. Thank you very much for helping me if it's possible.
I have a Sharp 70" but the codes should be the same; I use 11602
I did run into a problem with it controlling the volume until I figured out you have to do the Unlock code first; then set in the control code; make sure it works, then set the lock code so you don't lose the settings.
Aug 12, 2014 | Televison & Video
Dec 03, 2012 | Sharp LC-32SB24U 32 in. LCD TV
My Panasonic Model: THL32U20A will not respond. You can turn it on manually (not by remote) and once turned on, nothing works, IE: remote doesnt do anything and you cant even change channels or volume etc...
I too have exactly the same fault. The Tv even turns itself on in the middle of the night, i have to unpug it from the wall. It has been in for repair 3 times now, one guy said there is nothing wrong with it. I am keen to hear if anyone has had this fault resolved.
Thanks
Darren
Mar 13, 2011 | Panasonic TH32LRU20 32 in LCD TV
I cant turn my sharp aquos 32" on or off with the remote. I also cant mute it or adjust the volume.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
New remotes: www.remotes.com
Jun 29, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Volume Control is horrible - Sharp LC-32SB24U
If your using a remote control, try to replace the battery. if your just pressing the little buttons at the front of your tv, the buttons that your pressing is the faulty one. you must replace all those buttons in order for your volume to work perfectly. if you do not know how to do these, just have your tv repair by a professional tv technician. by the way, the little green k that your referring maybe the volume indicator
Jan 19, 2009 | Sharp LC-32SB24U 32 in. LCD TV
How do I get the volume to work on my sky remote control?
SHARP TV
follow the steps below
TV
RED + SELECT
TV
0093 (sharp code)
press the power button if this turns your TV off then press SELECT to save. If not press TV then POWER. repeat this step until it does turn your tv off remember to press the SELECT button to save the code.
Cheers
Little Dish Fitter
Sep 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 32"
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The volume control is stuck
you didn't mention even using the remote. any way if it does not control even doing manualy or with remote control contact the dealer of you tv and discuss the problem. This could happen now a days LCD tv's has a program to operate. i suspended the program of your tv has reset.
Mar 26, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-26D4U 26 in. LCD Television Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
