Question about Vacuums
Have had to replace the starter relay 3 times the starter keeps staying engaged its a 2004 suzuki 2004 intruder 1500vl
    Problem Solver:
  • 5 Answers
Probably the bendix sticking
Posted on Apr 16, 2014
I have used my dyson dc39 perhaps a dozen times tops and the brush bar won't stay spinning. I've stood it upright and turned it off, clicked the brush power button. Spins then stop-makes pop sound.
If it's like my DC-07, the brush shouldn't spin if it's upright, and also won't spin if you don't have the clutch for the brush fully engaged. Make sure that the back of the unit is tilted off of the fully upright position, and check that the brush clutch is all the way engaged - there may seem to be a middle setting, but that isn't really where you want to be. Hoping that helps.
Sep 13, 2015 | Dyson Vacuums
I have a vax compact bagless upright vacuum cleaner - model No. X-006 and the wheels keep coming off and each time I replace same after a very short while they come off again
These wheels usually are fitted by means of a number of lugs 3 or 4 on the back of each wheel and they are a press fit into holes in the vac body. If one of the lugs is broken or cracked at the base whe wheel wont stay on. I have repaired these with epoxy resin on the inside of the lugs but to be honest repairs don't last long.
Oct 20, 2014 | Vacuums
Switch is broken, need replacement
Scott,
You might want to try a full-Web lookup on that part by means of the http://ixquick.com Privacy-Positive Meta-Search Engine to locate a replacement for that old switch since the Searspartsdirect.com operation no longer provides them.
I caught a couple of mentions on eBay while looking-up the item myself a few moments ago; that venue seems likely from where I sit (with all the usual IFs and BUTs) applied.
Good luck! You seem to have some skills - if eBay etc do not pasn out, a leetle creative thinking just might result in an acfeptably operabvle and entirely clever jerry-rig using any old intact power switch that might fall into hand from Heaven.
Brother, do you pray? It often actually helps one to find Impossible Things such as this, I am happy to report from my own commercial small-shop experience. And that is all. 0{;-)o[
Aug 15, 2013 | Craftsman 508203 Switch
My Keurig will not stay on long enough to brew even one cup of coffee. The automatic shut off is on the off position. It only stays on seconds.
When is the last time it was cleaned? That's usually the issue & the quickest fix. If the Keurig gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup, also remove the carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths. Good Luck.
Jul 07, 2011 | Vacuums
Brand new electrolux range oven wont work, all that shows on display is F15
F15 means : signal lost between oven relay board & EOC(main computer board)
1. Test the harness and connections from EOC connector P16 to oven relay board J2.
2. Replace the oven relay board.
3. Replace the EOC.1. Test the harness and connections from EOC connector P16 to oven relay board J2.
3. Replace the EOC.
Hope this help. good luck to you.
Feb 07, 2011 | Vacuums
Myu easy flow central vacuum wi not shut off
This could be because of 2 things....
first, the on/off switch may have been accidentally hit and is forcing the machine to stay on at all times.
Second, the relay in the unit may be defective and stuck in the on position. Less than 5 years should be under warranty. The easy way to tell if it is this problem tho is to unplug one of the low voltage wires from the side of the unit. These are usually located near the power cord going into the machine. If the machine stays running it is the Relay. However if the machine shuts off, the wiring in the vac system may be crossed out somewhere causing the machine to stay on.
Nov 04, 2010 | Easy Flo EF2300 Central System Vacuum
The starter on our DC14 won't stay pressed down. We have to keep holding it down to get it to work. How do we fix this?
You must replace the switch its going bad. There easy to replace if you remove the hose youll see the screws.
Dec 17, 2009 | Dyson DC14 All floors Bagless Upright...
Power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
Nov 08, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson DC14 animal
this may sound harsh and i apologize in advanc. but dyson vacuums are just over priced pieces of junk. you would have gotten better quality out of a 39.00 bissell and now to the repair. the machine is made of cheep plastic which wears and breaks over time. the power switch, and button will have to be replaced which will cost you rougly around 70 bucks. and that is if you do it yourself. the beater bar stop could be a broken engage bar as well. meaning when you turn the nob to hard wood or to floors it turns the beater bar off, but when you turn it to carpet it kicks it back on. the mechanism that does that could be broke as well. i would make dyson warranty the vacuum if it is still under warranty. if it isnt i will say it is not worth the repair costs to keep it. im sorry to have to say this but they are disposable vacuums they are not built with quality.
Aug 09, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
