Question about Deni Classic Meat Grinder 3301
I bought a deni meat grinder but there was no cutting blade enclosed. The store is going out of business so I cannot exchange it. Now what?
    Problem Solver:
  • 5 Answers
Call the customer service number listed in the literature that came with your product. Even though the company is going out of business they should be able to ship you any missing parts.
Posted on Apr 16, 2014
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
No i'm only looking for attachments for my kitchenaid mixer model no. ksm90ww
State your country and someone will direct you. What is a batter blade, is that the flat paddle or a dough hook?
Jan 08, 2015 | KitchenAid Food Mixers
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The attachment for grinding meat on the front wont work ? mixing arm in bowl works fine ! why wont it engage?
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
Oster regency parts
There are all kinds of Oster Kitchen Center parts and attachments for sale on Ebay. Here is another site that sells Regency parts: http://www.Goodman's.net
Can you help me with my Regency problem? I bought a used one with the hopes of using a lot of the attachments including a meat grinder (did not come with), but now after receiving the OKC there is no hole in the side of the mixer arm to attach the grinder - there is a metal circle. Do I need to punch out this circle - like an electrician does with an electrical box? HELP
Ladydirector@verizon.net
Dec 28, 2008 | Food Mixers
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid sausage maker does not stuff the sausage casings
This may be a problem with assembly of the Sausage Stuffer Attachment. Your Use and Care Guide for both the Food Grinder and Sausage Stuffer could illustrate the assembly for you in detail.
Also, it may take up to 4 minutes after meat is fed through the top of the Food Grinder for it to start stuff into the casings. The meat is fed into the Food Grinder, ground, and then pressure is built up behind this ground meat to push into casings.
Jun 01, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Deni Classic Meat Grinder 3301 Logo
76 people viewed this question
Top Deni Food Mixers Experts
eyecam
Are you a Deni Food Mixer Expert? Answer questions, earn points and help others
