Question about Samsung Electric Range Oven Stove For Sale In Kentucky Ky Pick - Up Only
Touch to wake up button on Samsung stove does not light up
Everything on the digital screen lights up except the Touch to wake up button. Is this supposed to stay dark. It is very had to see on a black background.
  • Viki MCDonald
    Viki MCDonald Apr 18, 2014
    ON my new Samsung stove is a very arge digital screen. In order to activiate this sscreen, I have to tap teh function called"Touch to wake up" button. The screen light up, excepot for this pad. This stays dark all the time. Shoudl not his pad also be lit up all the time so you can see where you are touching???
  • 9 Answers
SOURCE: No picture
try chicking the horizontal section or vedio section...
Posted on Jan 29, 2008
SOURCE: Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Posted on Sep 27, 2008
  • 1684 Answers
SOURCE: Samsung 940bf-screen stays black
Your monitor is having a problem with the power supply. Because of the small spaces in the monitor case heat builds up and causes parts called capacitors to blow. If you can solder you should be able to do the repair yourself. Go to our web page2.gif at:
www.ccl-la.com/badcaps.htm and look at the pictures and repair guides. Open your monitor and look for parts that look like the pictures. Replace any that you see and your monitor should be back operational.Be sure to install the new parts with the polarity stripe on the side going the same direction as the bad ones came out. You will need to replace them with a high quality part with high temp value (105c). If you don't want to do the repair yourself we do offer a repair service.
I hope this helps, if so please rate my solution.
Buddy
www.ccl-la.com
Posted on Sep 10, 2009
MNfisherman
  • 11896 Answers
SOURCE: samsung digital camera L100 won't turn on.It's
Sounds like the software/firmware needs to be updated. Samsung will do it for $50 or you may be lucky enough to get a download off the web.
Posted on Oct 23, 2009
  • 3 Answers
SOURCE: Touch Keys and Screen
I think this a problem related to the flex cable that connects the main phone body to the sliding screen. Over time the flex cable wears down as it slides and results in a whole range or problems such as: display acting weird (eg. mirror-image and inverted colours), speaker not working, off-button not working etc.
Flex cables are cheap to buy on ebay (a few dollars) and there's internet sites that show you how to open the phone and replace them. (google: samsung u700 replacement flex cable)
Posted on Aug 25, 2010
How to reset a ipod touch
Perform a straightforward reset procedure on your iPod Touch if you are experiencing issues like freezing, unresponsive apps, delays or other other problems. Carry out a reset if your iPod doesn't respond when you attempt to restart the unit. This type of reset will not erase any content from your iPod Touch.
Locate the "Sleep/Wake" button on the top of the iPod Touch. Press and hold down the "Sleep/Wake" button and the "Home" button simultaneously. Continue to hold both buttons for at least 10 seconds. Release the "Sleep/Wake" button and the "Home" button when the Apple logo appears on the screen, indicating the device has been reset.
Apr 09, 2013 | Apple iPod touch
Reset my ipod 8gb touch screen 4th generation
Feb 14, 2013 | Apple iPod Audio Players & Recorders
Forgot everything to my apple account for my ipod
Feb 14, 2013 | Apple iPod touch
Samsung Galaxy S Stratosphere SCH-I405 Screen Issue
the flexes probably had been damaged by now, stratosphere is not that tough when it comes to water, unlike galaxy s3, you need a technician now for your phone to work, or better yet, look for the nearest samsung service center and bring your phone there.
Dec 07, 2012 | Samsung Verizon Galaxy S Stratosphere...
The screen is black except for the apple icon and status circle and i can't get it to do anything.
Try to reset the iPod Touch by pressing and holding both the Sleep/Wake button and the Home button for about eight to ten seconds. Wait for the Apple logo then let go of the buttons.
Hope this helps. Thank you for using FixYa.
Feb 26, 2011 | Apple iPod touch
My Ipod touch will only turn on when plugged into the wall or the car charger. When connected to the computer the apple logo flashes on and off but will not do anything.
do this...
While connected to a power source, try to reset the iPod touch. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged. if still doesnt power on try this.. Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
    Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  4. Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:
  5. If necessary, open iTunes. You should see the following "recovery mode" alert:
  6. Use iTunes to restore the device.
also maybe your unit have been in contact with liquid You can tell if the headphone-jack Liquid Contact Indicator has been triggered by looking directly down into the headphone jack. Use a lighted magnifying glass or angle the iPhone or iPod so light shines down into the headphone jack. At the base of the headphone jack, you should see what is normally a white or silver-colored dot. The dot will become full or half red or pink when the dot has come in contact with water or a liquid containing water. To view the dock-connector indicator on iPhone 3G or iPhone 3GS, use a lighted magnifying glass and hold the device so that you can view the center bottom of the dock-connector housing. A full or partial red dot will appear if the indicator has been triggered.
a feedback would be much appreciated
Jun 06, 2010 | Apple iPod touch Second Gen (8 GB,...
My Ipod touch Safari application has the bookmarks screen in front to the browser page, so I can't load new pages. the touch screen is unresponsive except for the 'new page' and 'back and 'forward'...
I would reset the ipod touch by pressing and holding the sleep/wake button and the home button at the same time for at least 10 seconds until the apple logo appears. Hope this helps.
Nov 13, 2009 | Apple iPod touch
My ipod touch screen is frozen
Try this: Press and hold the wake/sleep button and the home button simultaneously for ten seconds and the apple logo should appear on the screen. Release the buttons and it should work like normal. Hope this helps.
Apr 19, 2009 | Apple iPod touch
Samsung Electric Range Oven Stove For Sale In Kentucky Ky Pick - Up Only Logo
42 people viewed this question
Top Samsung Kitchen Ranges Experts
ray gallant
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
