Question about HP 255 G1 F2P86UT 15.6" LED Notebook - AMD - E-Series E2-2000 1.75GHz - Charcoal 4 GB RAM - 500 GB HDD - DVD-Writer - AMD Radeon HD 7340 Graphics - Genuine Windows 7 Professional 64-bit - 1366 x 768 Display - Bluetooth
Keyboard freezing - HP 255 G1 F2P86UT 15.6" LED Notebook - AMD - E-Series E2-2000 1.75GHz - Charcoal 4 GB RAM - 500 GB HDD - DVD-Writer - AMD Radeon HD 7340 Graphics - Genuine Windows 7 Professional 64-bit - 1366 x 768 Display - Bluetooth
  • 28 Answers
Check for new windows updates, could be a driver issue.
Posted on Apr 16, 2014
Keyboard is no longer working on the HP laptop and also the laptop 'freezes'
If your laptop freezes and the keyboard is not working, you most likely have a defective keyboard.
Before replaceing the keyboard, check all your usb ports for broken or bent pins on the laptop
Apr 15, 2014 | HP Computers & Internet
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
Toshiba laptop keyboard keeps freezing up
Plug in a USB mouse and keyboard if the problem continues, then it's a bad install or bad motherboard. If the external keyboard is fine, then it's usually a palm rest or keyboard connection problem. If this model has a nub button in the center of the keyboard, these are often problematic and can be easily removed.
Nov 09, 2012 | Toshiba Computers & Internet
As I remember it, the EX 100 was plug and play on my XP PC. The batteries are NOT a problem - as they check OK. I periodically have both mouse and keyboard FREEZE After restarting XP computer everything...
Connect an additional wired keyboard to your pc. And when the freeze happens check if the pc responds at all, using the wired keyboard. If its not responding , its an indication of a faulty PSU or motherboard.
Mar 08, 2011 | Logitech Cordless EX 100 Mouse
Computer freezes everytime I press a key on my keyboard
unplug and replug the keyboard
perform a powerdrain i.e. unplug the power cable frm the computer .... press and hold down the power button for 10 secs and then plug the power cable and turn on the comp
BEST OF LUCK
Mar 07, 2010 | HP CPQ175KB Keyboard
Can't access laptop computer in safe mode, keyboard freeze up
Try booting your system from a LIVE cd like linux, a verson of Hiren's tools, or the UBCD (ultimate boot disc for windows). If your keyboard still freezes with the alternate OS, you may have a hardware malfunction.
Jan 18, 2010 | Compaq Computers & Internet
Medion keyboard keeps freezing
Keyboard freezing is usually an indication of a problem with windows (Usually Spyware or viruses) If you can, download Malwarebytes from download.com and see if it helps
Sep 29, 2009 | Medion md40298 Notebook
Computer Freezes unless pressure applied
With the laptop turned off, take out the hard drive completely from the laptop and then reseat it back into its slot and make sure its nice and snug.
Then go ahead and turn it on and see it will run without freezing on you and having to apply pressure on the keyboard.
If that doesn't work then disconnect the keyboard and see if it will run smoothly without the keyboard. If it does then you might have a stuck key on the keyboard that is making the unit freeze so you might have to replace the keyboard.
Jul 06, 2009 | IBM ThinkPad T43 Notebook
Keyboard Problems
This is the common fault with usb keyboard and mice, on certain motherboards, as the driver has to load first on the system on boot up but tends to to load later, than the bios recognising your keyboard, making the sytem freeze as it tends to look for the keyboard first. There is no real solution to this as it is all down to what is called interupt request (IRQ). If your keyboard is set by windows as IRQ2, then it is the second peice of hardware to be started, so ideally it needs be IRQ1 to startup first. Experiment using different usb ports as one may have the IRQ1 and not cause the freeze. Sorry this is a bit technical but, theres no easy way to explain.
Jan 12, 2007 | Logitech DiNovo Cordless Desktop...
HP 255 G1 F2P86UT 15.6" LED Notebook - AMD - E-Series E2-2000 1.75GHz - Charcoal 4 GB RAM - 500 GB HDD - DVD-Writer - AMD Radeon HD 7340 Graphics - Genuine Windows 7 Professional 64-bit - 1366 x 768 Display - Bluetooth Logo
46 people viewed this question
Seeker5211
Seeker5211
