Question about Craftsman 25cc Gas Line Trimmer
Cutter spins freely
My 30cc craftsmanweedwacker runs well but the cutter head does not seem to be connected to the drive shaft
    Problem Solver:
  • 7 Answers
The driveshaft is broke in the tube or the head drive is broken or srtipped out. Take head off and pull out the cable. It just slides out.
Posted on Apr 16, 2014
My ryobi 30cc grass cutter model rtp 3000 runs but no power to cut gass
I have seen the flex cable broken between the power head and the cutter head .
Feb 20, 2016 | Stihl FS 85 Weed Eater
Why does the head stop moving?
with trimmers , there is a shaft or as in a bent shaft a cable that has square drives and ends
these can become oval or break off if continual heavy loads are applied to the cutter head
next there is a centrifugal clutch at the top of the shaft and if continually used in heavy work that clutch will wear out and not grip sufficiently to drive the shaft
most cutter heads do not suffer problems other than to get loose and work down the tube thereby allowing the square drives to part
Jun 24, 2015 | Craftsman WeedWacker Gas Trimmer 25cc...
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Why doesn't the cutting head on Stihl F38 trimmer spin?
Maybe the cutter head has come loose from the shaft. make sure the head is engaged to the drive tube properly
Jul 09, 2014 | Stihl Garden
Ok my ace 2000 disposal hums. blades move freely when i put my hand inside. the 1/4" allen wrench doesn't fit in the opening at the bottom. my sink fills with water but eventually drains, so I...
Sounds like the starter winding is bad.
The cutter disc is welded directly to motor shaft. So is the allen wrench fitting.
So if disc rotates freely, then you should be able to feel the allan wrench fitting rotate too.
Use broomstick instead of hand down disposal.
If motor hums and cutter disc does not spin, but cutter disc can be moved freely, then disposal needs to be replaced.
I wish they made repairable motors so that metal and copper doesn't get thrown into the scrap recycle metal bin.
I wrote ez disposal replacement tips:
http://beta.fixya.com/support/r7929008-replace_garbage_disposal
Oct 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Engine run but don't turn
You're a bit vague in your problem description here, but I'm assuming you mean that when you give your machine gas that the cutting head will not turn. First I would check the cutter head to be sure that no trash has wound itself around the shaft preventing the head to turn...if that is not the problem turn the cutter head by hand and check to see that the bearing inside the cutter head has not seized, it should turn freely with no noise....if no joy check the cable which runs through the shaft from the engine to the cutter head it may be broken or frayed, also check to see that there are no problems with the clutch (broken springs, broken pads, or a broken key) that should do it ...hope this helps...;-D
Aug 09, 2010 | Ryobi Garden
What causes a bush cutter to vibrate
The vibration generally comes from the rotation of the motor, and the cutter head. The faster it spins the greater the vibration.
Cheers.
Jul 09, 2010 | Tanaka 40cc Bicycle Handle Straight Shaft...
On my TrimMac 210 when the engine is running the cutter head does not turn
When the engine was running there was no drive to the cutter head. It appeared that the bearing at the bottom of the flexible drive shaft had worn away from the three crimped marks in the exterior drive tube and slipped down, thus the flexible drive shaft inside the main tube was not reaching the cutter head. I made up an exterior tube that just fitted over the main drive tube. I Drilled a 6mm hole through the exterior tube and the main drive tube into the worn bronze bearing. I then brazed a 6 mm nut onto the exterior tube and screwed a 6 mm bolt and lock nut right into the bearing inside the main drive tube. This stopped the bearing moving down and away from the interior flexible drive. The trimmer then worked as it should do. Good Luck, Tony Hillyard, Pleinesa Oeuvres, France
Aug 30, 2009 | McCulloch Trimmer Plus Attachment: Add On...
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 | Garden
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Craftsman 25cc Gas Line Trimmer Logo
136 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
