Question about Kenmore km 66515765692 3377274 Ctr Spray Arm Dishwasher
Upper spray arm come off - Kenmore km 66515765692 3377274 Ctr Spray Arm Dishwasher
3 Suggested Answers
  • 188 Answers
SOURCE: Hi I have a Kenmore model
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to because the door will be open, but if you feel more comfortable shutting off the power to the dishwasher, do so.
Posted on Mar 06, 2009
SOURCE: lower spray arm is not rotating
call sears help line thewy have mech that can help
Posted on Mar 14, 2009
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
Mod m.d.c.5100aww ser28126829ax I had a repairman come out. He said the "sprayers" are plugged. I'm on a fixed income. With my bills I can't afford to get it fixed. Trying to fix it myself. I...
Most dishwashers dispense the detergent via gravity and the sprayer arms spraying against the soap dispenser once the little door flips open during the wash cycle. Since it sounds like the soap door is opening I would look at the sprayer arms and make sure they are free of food particles or other debris that might be keeping them from rotating and spraying properly. Here are some instructions for performing this check.
Remove the lower dishrack from the unit. Reach into your dishwasher and spin the lower spray arm. Take note of whether or not the arm moves freely or if its movement is restricted. It should not be restricted in its path of motion. Now gently pull up on an end of the spray arm. The spray arm should be free to wobble up and down. Unscrew the arm retaining knob (some of these are left hand threads) and take the arm out for inspection and carefully examine the spray arm seams. If they have split or are damaged, the dishes may not receive the amount of water pressure required to fully clean the dishes or to rotate the arm properly. What’s more, if water is in fact spraying out of the spray arm from its seams, it is possible that it can cause your dishwasher to leak. Make sure there is no debris in any of the holes.
If your dishwasher has a spray tower, pull up on it as far as it will go and then let it fall back down. Again, this movement should not be restricted. It should be a fluid and smooth motion. Also, unscrew the spray tower and examine it for any debris or foreign objects. Remove any that you find.
Gain access to the upper spray arm by removing the upper dishrack. Perform the same tests for the upper spray arm as you just did for the lower spray arm. Keep in mind that the upper spray arm may not wobble as much as the lower spray arm.
On a final note, some dishwasher models have a water tube that meets up with the upper spray arm once the upper dishrack is pushed back. It is a good idea to check to make sure this tube is aligning properly with the upper spray arm and that this has not split or is damaged in any other way.
Mar 24, 2008 | Dishwashers
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
Spray arm stopped spinning
Which one the upper or the lower spray arm? If the lower is spraying and the upper isn't.. Check the spout pipe to the upper sprayer arm, it is pluged. Or the sprayer arm is wore out around the fitting. GB...stewbison
Aug 31, 2011 | Dishwashers
The top shelf is not getting clean. There is food residue on the glassware that was not there at the start of the wash.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
Dec 14, 2010 | Frigidaire Professional Series 24 in....
Water not pumping to upper spray arm
First,
See this link for a picture of the upper spray arm and manifold assembly.
http://www.apwagner.com/index.php?main_page=model_lookup&model_num=KUDP02IRBL0&model_id=163723&diagram_id=380403
Referring to parts 1, 6, and 9, make sure everything is attached, secure, and lines up when the upper rack is pushed back into place.
It's possible the pump is obstructed and not delivering water to the upper arm, but the more likely cause is a displaced upper arm feeder tube. If no luck, start checking for obstructions in the feeder tube, manifold and the spray arm.
Mar 14, 2010 | KitchenAid 24 in. KUDP02IR Dishwasher
UPPER LEVEL SPRAY DOES NOT SPIN - UPPER LEVEL NOT
plugged spray arm holes, pump intake partially blocked, too little water getting in tub cuz screen in fill valve has debri
Dec 21, 2009 | KitchenAid KUDC25CH Dishwasher
Top rack does not wash dishes.
Possible causes of spray arm inefficiency:
Loading large or tall items in the lower basket which stops the arm revolving.
Upper spray arm split along seam.
Upper spray arm blocked.
Under dosing of powder causing foam and reducing upper spray arm water pressure.
Blocked strainers reducing water to circulating pump, therefore reducing upper spray arm water pressure.
inefficient wash motor impellor (faulty)
Dec 21, 2009 | Kenmore Dishwashers
Upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Sep 22, 2009 | Dishwashers
Upper arm does not spin
No I don't believe its the pump. I believe the lower spray arm is possibly split open on the side causing a loss of presure and flow to the upper arm and overloading the door seal. As well the loss of flow to the upper arm will resulted in it turning too slow.
Aug 12, 2006 | Frigidaire 24 in. FDB635RF Built-in...
Kenmore km 66515765692 3377274 Ctr Spray Arm Dishwasher Logo
19 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
