Question about Brother MFC-7440N Laser Printer
Drum and Power On
After the end of drum life, the printer turned off by itself. I replaced the drum but it doesn't power on. Is there anything I can do to fix that?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Have the printer "Fuser" tested. It might be the reason behind that.
Posted on Apr 16, 2014
timeattack
SOURCE: Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Press 1 to reset the drum count
Close the over
Posted on Feb 06, 2009
SOURCE: how to reset drum counter for brother hl4070cdw laser printer
When you replace the drum unit with a new one, you need to reset the drum counter by completing the following steps:
  1. Turn the printer power switch back on.
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
Posted on Aug 29, 2009
MNfisherman
  • 11896 Answers
SOURCE: drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Apr 19, 2010
  • 30 Answers
SOURCE: drum end soon, what does that mean
It means that the drum will end soon. The drum is the piece that holds the printer cartridge. It costs about 115+ dollars at the store, but on ebay, you can get it for a good 60 bucks. :)
Posted on May 27, 2010
SOURCE: How do I reset my drum life once I have inserted a...
Open front cover; hit CLEAR button; hit PLUS (up) button. Close cover. Done.
Posted on Aug 31, 2010
Konica minolta pagepro 1500w drum error
The Pagepro 1500 is an older design and the drums on those are only rated for around 12,000 pages or so. Unless you have a computer that can query the printer directly to get the error code the print driver is giving I can only recommend disconnecting power, remove toner, remove and replace drum, replace toner and reconnect power. (Cold reset) But, if the drum has reached its end-of-life then the only option is to replace the drum. At that point it's better just to buy a new printer; the drum replacement cost will probably be prohibitive.
Oct 26, 2016 | Konica Minolta Office Equipment & Supplies
Tip
How to extend the life of a TN-330 drum kit for MFC-7840W Wireless Printer
If you have received any of the following messages on your Brother MFC-7840W wireless multifunction printer while utilizing the TN-330 drum kit then you may not have to replace your drum, at least not yet.
Drum End Soon
Drum Error
Toner Life End
Toner Low
I had this issue happen to me about 150 pages ago (some text, some pictures) and I still haven't replaced my drum after I executed this little trick.
Take your drum kit out of your printer (make sure you turn off and unplug any cables first)
Take some black electrical tape and cut a inch by inch square off.
Place the black tape over the optical port as shown in the picture below.
Then put the drum back into the printer, cable everything back up and turn the power on.
Your drum should last a long time beyond what was supposed to be a low toner.
Hopes this saves you some money.
on May 19, 2010 | Brother MFC 7840W Printer
How to repair or replace the drum on "Brother HL-4070CDW" Printer
You can reset the drum count, it will only affect your prints as the drum wears out. If the quality is still good, you can just keep on printing, but will eventually have to replace it.
Reset:
  1. Turn on the Printer's Power. ...
  2. Select "Machine Info" by pressing "+" or "-" keys on the top front "Control Panel".
  3. Press "OK".
  4. Select "Reset Parts LIfe" by pressing "+" or "-" keys on the top front "Control Panel".
  5. Press "OK".
Nov 08, 2017 | Brother HL-4070CDW Color Laser Printer...
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Printer is dsplaying"drum error" to
According to your problem, may be the drum is not usable now. But first clean the toner drum properly. May be this may occurs for setting of the drum in printer. So resets the drum carefully inside the printer after clean it. Then reboot the printer and the system both. If it doesn't solve your problem then change the toner. It may help you or you have to change the drum or cartridge.
Jun 27, 2011 | Brother DCP-7040 Laser Printer
I turn the printer on and it goes solid red right away. i try to print and it doesn't do anything
Either the drum or the toner needs replacing. If you've replaced the toner recently, then the drum has reached its end of life (counter controlled). You'll have to replace the drum before it will come back to life again.
Aug 10, 2010 | Brother HL-5240 Laser Printer
How long will the drum last on a Brother HL 5140 when the yellow drum light starts flashing
I have reused the drum for three life cycles and the print quality is still good. Just reset the counter until the print quality suffers because the cost of the drum exceeds the price of a new printer. According to Brother to reset the counter
  1. Turn the printer off.
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
Apr 10, 2009 | Brother HL 5140 Laser Printer
How to reset drum counter for brother hl4070cdw laser printer
    "Reset Parts Life".
Mar 27, 2009 | Brother HL-4070CDW Printer
'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
May 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
Brother MFC-7440N Laser Printer Logo
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
