Question about PDP Rock Candy Controller For Playstation 3
I have only had my controller a couple of weeks and it is over heating and turning its self off. Is this a common problem or do I have a bad controller
  • Angela Wilkins
    Angela Wilkins Apr 18, 2014
    Should I return to store and buy a different brand? Is this a common problem?
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
At first, it took several cycles to dry a load of clothes in our Kenmore elite elect dryer. You could not rely on the dampest setting at all. Depressing the door switch and turning on the unit, it would...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Dryers
Dryer heats however will not turn, prior to it stopping it was making a loud squealing noise for weeks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Feb 12, 2011 | Maytag MDE308DAYW Electric Dryer
The unit will turn on but there is no heat. i have cleaned the unit and checked for blockage. the unit will run and won't shut its self off.
No heat is usually caused be either by a bad heating element or a plugged vent. Many vents also have a flap inside of them that close when the dryer needs to heat up and opens when it needs to cool off.
Also when a dryer doesn't shut off, it is usually due to a fault timer.
If you have a bad control board which is fairly common, you will have more than one component that is not operating correctly.
Jun 14, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
TV turns off by its self
U might have sleep timer on?Push the menu to see it have 30,60,90,120.If u don't ur tv have problems.Call for warenty repair,or return it were u purchase for an exchange.
Feb 07, 2010 | Insignia IS-LCDTV32 32 in. Television
After self cleaning the oven, now the oven won't heat up
Usually this is caused by either a bad temperature sensor, a shorted wiring harness, or commonly a faulty controller. The temperature sensor and wiring can be checked with an ohm meter.
When you program the oven for a high temperature what does the display read after ten minutes or so?
- www.fixyourboard.com
Jul 29, 2009 | Whirlpool RBS275PD Electric Single Oven
I own the Saeco Magic Deluxe machine - when we turn it on, it never heats up.
this could be a couple of different problems.
1. the heating element has gone bad (seldom).
2. the drive electronics on the control board have died, which means you need a new control board. (fairly common).
3. the wires connecting the heating element have come loose (was someone inside your device?).
4. the thermastat on the heating element has gone bad (open) and needs replacing. (measure with an ohm meter after disconnecting the connector to the control board).
If you decide you want to trash this unit, I'd pay for shipping to have the parts. I am keeping my old (12+ years) machine alive. already replaced 2 control boards. (email stephen@muc.de, i'm located in CA, USA).
Hope this helps, stephen
Jun 29, 2008 | Saeco Magic De Luxe Espresso Machine
Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Aug 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
PDP Rock Candy Controller For Playstation 3 Logo
Top PDP Video Game Consoles & Games Experts
James Wishart
Are you a PDP Video Game Console and Game Expert? Answer questions, earn points and help others
