Question about Cameras
Digitrex ctf4071a tv
No picture or sound.....led light (Start) can change from red to green using remote...but nothing else. Any help?
djnick989
  • 1067 Answers
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Posted on Jan 29, 2008
javswr
  • 44 Answers
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Posted on Feb 28, 2009
  • 1348 Answers
SOURCE: When i on the tv by remote the red standby light
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Posted on Jul 08, 2009
  • 293 Answers
SOURCE: tv will not turn on
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Posted on Jul 03, 2011
SOURCE: Code to enable sky remote with Digitrex TV
I have a digitrex tv with remote indicating on reverse serial numbers( CTF2685. CTF3271. CTF4071) which I couldn't turn the volume up or down change the channel etc but this worked for me 1.press the tv button
2. Press select and the red button at the same time for 2 seconds the light will blink twice.
3. enter code 2193 and the light will blink twice. Problem was then solved sky remote fully functional hope this helps people out sure helped me thanks guys
Posted on Sep 16, 2012
How can i repair a tv that turns on but has no picture or sound
Have you tried a factory reset? I had a similar problem my TV was stuck on standby (red light only) I did this
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
and it worked!
Oct 16, 2015 | Sony KDL46EX400 46 in. HD-Ready TV
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Standby light changes from red to green
hi this fault could be down to capacitor in the power supply, they bulge or go leaky, you need to take the back off the tv, to have a look. try and find a tv tech in your area hope it helps
regards
shaun
Jan 05, 2014 | LG 42PX5D 42 in. Plasma HDTV
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Mar 08, 2010 | Televison & Video
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Help I have no picture, no sound. red light on front, 3 out of 4 green leds inside.
i would first replace the convergance ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 22, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
