Question about Microwave Ovens
I bought Daewoo Microwave Convection/ Grill Oven KOC-8H4T and I tried to heat a sandwich, after the time is over I open it and everything normal it's just that the sound of the microwave was still lou
Still make a loud sound even after the microwave finished heating
SOURCE: Daewoo KOC-985T - Help me find manual!
http://www.2instructions.com
Posted on Feb 05, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
SOURCE: Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Posted on May 02, 2009
SOURCE: loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Posted on Sep 08, 2009
heatman101
  • 43501 Answers
SOURCE: Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
My microwave just made a loud sound. It still runs but doesn't heat up. Is it likely a fuse & if so what do I do?
fuses make very little sound when they blow so a loud sound in a microwave is an expensive sound
best take it in for a proper diagnosis and quote as many loud sound repairs cost more to fix than a new unit
Dec 05, 2016 | Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
What size/kind of fuse does a Daewoo Microwave/Convection oven, Model KOC-925T use?
Its must be written on the nameplate in atransformer so open it and check
Sep 16, 2014 | Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
My Daewoo microwave is model KOC-9Q1T/KOC-9Q1TSL I notice that the plastic frame around the top of the door is wrinkled, as if it has melted. I have photos of this if you need them. Please let me know 1....
Plastic will melt but the door frame is metal and will not. So there is no safety issue here, just looks.
One could replace the door assembly if required. I would leave the door open after convection cooking to let the heat escape without heat build up causing the plastic to mishape.
Mar 11, 2011 | Daewoo Microwave Ovens
Daewoo koc-985t bi - Not heating food equally. ie. middle of food cold. Sometimes food takes double the time to warm.
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 18, 2011 | Daewoo KOC-925T Microwave Oven
Everything is ok, only not heating
Basic
heatman101
Dec 04, 2010 | Daewoo KOC-925T Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Sparks coming from back of microwave
If you coffee container had any metallic logos or paint on it sparks will occur. Try to heat water in the glass container.
Dec 11, 2009 | Daewoo KOC-925T Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
