Question about Sony Cyber-shot DSC-H50 Digital Camera
Message "turn power off and on again"
Lens was coming out 1 time, after that it doesn't go back inside anymore. Message "turn power off and on again" is appearing all the time. I have tried to reset factory settings; this is not helping. What can I do now? Please help.
    President:
  • 512 Answers
Your camera has dirt in the lens, you need to get someone to take camera apart and clean it. This is very difficult to do if you dont have any knowledge of cameras. You could send to sony, they will repair, around $95 plus shipping. Kind of expensive. Cheaper to buy new camera. But you have nothing to loose by trying to take apart clean and lube lens.
Posted on Jun 18, 2009
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
Turned camera on gives error message to turn off and back on again . No matter how many times we turn off and on it won't clear the message. Took battery out.put back in. Message still there. Also len
Camera was probably dropped. Motorized autofocus lens was probably damaged when dropped. It doesn't get more of a big deal than this. Depending on age of camera, it may be a ''wipe-out.''
Ps... I'm saying ''probably'' dropped because I didn't see it happen, but this is precisely what happens when they are dropped. It doesn't take much of a ''jolt'' to do the damage, and there is usually never any external damage.
Oct 09, 2012 | Cameras
My lens does not retract when i turn the power off. When i turn it on again the message 'turn power off then on again' keeps coming. what can i do
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Dec 13, 2010 | Sony Cyber-shot DSC-H10/B Digital Camera
Camera turns on, lens cyles (in and out) 3 times, then camera displays a message "Turn the power off and on again" superimposed on the display. Image is not in focus and camera will not take picture, just...
This is lens mechanism problem and lens assembly will be replaced to fix the issue.
Lens tries to correct its mechanical error three times then gives up and you see turn power off and on again display in lcd. If camera is under warranty, please call Sony to get it fixed or take camera to local camera repair shop if its out of warranty.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Error message, cant take pictures
Camera needs to be serviced. This is a common problem with sony cameras. If you have any knowledge of electronic, you could take apart and clean and lube lens. If not sony will fix for a fee, go to the sony web site, they offer a repair service. This happened to mine, it cost $95 plus shipping costs to repair. Now it works great, for how long who knows.
Jul 17, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
'Please turn camera off and then on again'
The barrel is defect inside,dit it fall on the lens? A new barrel will cost about 175 euro.
Jun 07, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Lens go in and out several times, then I got message to turn off
I have faced same message "Turn the power off then on again" today.I tried to on-off several times.finally I discovered that lens is so dirty.when I cleaned the lens it come alive :)
Apr 06, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
"Turn the power off and on again" error message
You probably have a defective lens assy. When turned on lens has to move to certain position but because of broken gear or some mechanical problem it can not perform that funtion. Remedy is to disassemble the lens assy and repair the problem. Many time the whole lens assy are replace to repair the problem. normal repair charges for this kind problem is $125-200 in US depending on parts use.
Mar 19, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Sony Cyber-shot DSC-H50 Digital Camera Logo
242 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
