Samsung display flickers LA32C450E1
I'm using a samsung 32" LCD from last 3 yrs. Recently, I've used a new setup box. Now, I am observing a lot of flickering display with or without the setup box.
jerryg50
  • 1667 Answers
SOURCE: screen flickers
This an be the power supply, or there is a component on one of the processor boards that is starting to fail.
The only way the tech can service this is to have the set opened, and wait for the fault to occure. When the set is doing the fault, he has to check the power supply distribution outputs, and at the same time use a digital scope to follow the video path through the various stages. This is a long an complicated process to find the exact fault.
Once the tech knows which board is giving the fault, he can then change the complete circuit board to fix the set.
I think what is happening is that when the set is coming in, they are not spending the adequate amount of time on it to find the fault. This type of problem is very time consuming to find.
What you can do is make a video of the fault, write the video to a DVD, and bring the set back with the DVD to show them the fault.
If you have a friend with an HDTV you can bring your DVD player to his place and try it for a while on his TV set. This would verify the player for sure.
I doubt you have an AC power problem. You can easily prove the AC power by putting a lamp on it.
When I have had this type of fault, I ended up finding the defective board in the TV and replacing it. One time, it was the customer's DVD player that was causing a fault.
Next time you buy a TV set I would suggest to you to pay a little more and stick with a major brand of TV set. They have better factory support, and are of better quality.
Jerry G.
Posted on Apr 27, 2008
SOURCE: samsung 40 inch lcd mode not supported
My 360 and samsung hdtv worked fine for about a year and now im getting the problems mentioned above, not sure if its a console/cable/telly problem but i did the following (temporary?) fix
Unplug your 360 and plug it into another television set, it seems to reset/calibrate itself somehow and then when you plug it back into your samsung tv it will work - mine did but for how long i dont know.
J Bizzle
Posted on Sep 22, 2008
stonephoenix
  • 563 Answers
SOURCE: when i turn on my samsung lnt5271 the screen seems
This sounds like a repair issue. I do not believe there is any in-home troubleshooting that you can try that will fix that particular issue. I would call Samsung tech support to see what their opinion of the problem is. Their number is 800-726-7864.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
tvtek
  • 1284 Answers
SOURCE: my 32 inch samsung lcd tv has got faint black
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Posted on Nov 18, 2009
SMEG-HEADS
SOURCE: Bush 32" LCD 1080p tv
if the screen flickers in thin lines across horizontaly then it the progressive scan on the HD side, mine does the same so i turn the brightness and sharpness down... problem solved (for me) also mine is ok through scart 1&2, DTV (digi) and ATV (anna)
Posted on Jan 17, 2010
Television reset
Hi les
Try to apply fine tune..
Jan 18, 2014 | Televison & Video
La32c450e1 lcd not working only red light on
This may mean that the Back light or a capacitor is blown, you may need to seek a repair shop or buy a new TV. Unless you're good with electronics.
Dec 07, 2012 | Samsung LA32C450 32 LCD TV
When I first turn on the TV there are 3 transparent lines that appear.
The data buffer IC inside of the display panel is bad. It needs a new panel.
Apr 20, 2017 | Samsung LNT4066F 40 in. LCD Television
DIGITAL NOISE FILTER PROMLEM IN LA32C450E1
hello,
Digital noise problem on samsung LA32c450 because of Store Demo setting.
Enter to menu, choose setup, plug and play, choose home use.
read my tips here .
good luck.
Jun 24, 2011 | Televison & Video
PIXILS FLICKER THROUGHOUT THE PICTURE.
I'M SORRY TO HAVE BOTHERED YOU, I DID NOT REALIZE WHEN THE CABLE CO.
CHANGE EVERYONE TO DIGITAL IT MAY HAVE AN EFFECT ON PEOPLE EVEN
THOUGH THEY ALREADY WERE ON CABLE.
THANK YOU FOR INQUIRING.
Jun 04, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Laptop screen goes blank at random times.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
Go to www.lcdparts.net for parts detail and installation
Feb 28, 2009 | Dell Computers & Internet
There is lot of disturbance on the screen
Control Panel
Display (or Display Properties)
Settings tab
Advanced
Monitor tab
under Screen refresh rate, change to 70 hertz or higher
Apply, black screen
(Your desktop has been reconfigured. Do you want to keep these settings?) Yes
OK
OK
Nov 03, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
