Question about Jet 414551 J-4200A Industrial Disc Belt Sander / Finisher
Fix sander Will start run slow then trips breaker
    Master:
  • 876 Answers
You likely have something bound up or a bad bearing. Take the belt off and turn things by hand to verify they work smoothly
Posted on Feb 05, 2015
2 Suggested Answers
  • 143 Answers
SOURCE: unit never get to full running speed before
earth lekage fault most likely. Return to service centre
Posted on Sep 20, 2009
Circuit breaker trips out
What is the rating of the breaker? Is this enough to run the saw? If this is ok, has the motor become damaged or has the blade got dirt or wood dust slowing it down?
Jul 25, 2014 | Hitachi C10FR 10" Job-Site Table Saw 15...
I have a 5kw generator it was working fine I use it on the oil fields to power my little rv suddenly every time I turn on the air con it trips the breaker and now im using a air compressor and at first...
A number of things can cause this. A sit worked before !
Basically:
Engines get older and can't hold HP which causes the rpm to slow and voltage dip, this causes a current increase and trips.
Breakers also get weaker especially if they trip a few times
HVAC and compressors pull approx 6 times the current to start as they do to run, once they have run a while, they build up higher head pressures which cause harder starting and more current draw, hence the breaker tripping.
It's hard to pin point which is the actual issue, but these all contribute.
Aug 08, 2013 | Briggs & Stratton Power Products 5,550...
Clarke sander
Once we plugged it into an outlet with a trip switch it worked.
Jul 28, 2013 | Tools & Hardware - Others
Oscillating drum sander runs a few minutes and stops
This usually occurs if the motor is overheating and the internal circuit breaker is tripping. After it cools down, it self resets. This can be caused by bad bearings or parts dragging the motor down, making it work hard enough to over heat and trip the breaker. If you are running it on an extension cord or circuit that isn't able to provide it with the amps it needs the motor will overheat and trip the breaker also.
Dec 02, 2012 | Delta 17-960 Oscillating Spindle Sander...
Clarke CS4-6D Belt and Disc Sander
Junk basically. After very, very light use (still using first belt) it now makes a loud pop, followed by a burning smell, and trips the mains switch in my house! It was very slow to begin with and is now dead after about 2 hours of total use.]
If you find out the best disc/belt sanders go to the link
Practical WEN 6502 Sander Review For Improved Sanding Skills
Jan 10, 2012 | Tools & Hardware - Others
Trips breaker
You could have a dirty condenser coil or the fan motor isn't running at the proper speed to slow, weak or bad breaker, breaker to small causing to much voltage drop, loose plug in connection at wall outlet.
Jun 29, 2010 | Whirlpool ACQ128 Air Conditioner
Dead. Power is connected, wires are in tact. Just died when I was using it. Is ther an internal reset?
Try to plug something else into the outlet, just to make sure that the breaker didn't trip.
Try to run the sander without a belt. It may be in a bind.
With the sander unplugged, check the motor brushes. Replace if necessary.
If everything above checks out OK, you may have a loose wire.
Regards, --W/D--
Jul 13, 2009 | Ridgid 3 X 18 Belt Sander
Sander failure when using honda generator
If you are using a 220 volt 4 hp floor sander, which is 95% of all floor sanders. you CANNOT use a generator less than a 25KV, which is about the size of a van. All Floor sanders draw over 80 amps at start up and during floor sanding all sanders run around 25 amps. If your motor is a Capactor style motor you can do detrimental damage to the motor. Many of my customers have done it in the past.
Dec 24, 2008 | National Tools & Hardware - Others
Jet 414551 J-4200A Industrial Disc Belt Sander / Finisher Logo
Top Jet Tools & Hardware - Others Experts
Craig Butler
Craig Butler
Tom Chichester
Are you a Jet Tool and Hardware - Other Expert? Answer questions, earn points and help others
