Question about Car Audio & Video
What other MTX Thunder amplifier can i hook up with a MTX Thunder 6152 amplifier??
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 82 Answers
Not sure what you are trying to do, but you don't hook up one amplifier to another. You can pick any brand or model amp to drive other speakers than the ones that you are driving with the 6152. Just consider the power needed to push the speakers at the impedance they are rated(and hooked up)at. Look at the owners manual to determine if you need another amp. Hope that helps a little.
Posted on Apr 20, 2014
  • 113 Answers
SOURCE: MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Posted on Aug 08, 2007
  • 86 Answers
SOURCE: Schematic for MTX Blue Thunder Pro 752 amplifier
hello ..try this ...www.eserviceinfo.com...takes a bit of working out how to get them .when you do .you have to download bitzipper (these are a rar file)...then adobe 8 ..bitzipper can convert to a pdf flie so you can read them...hope you have some luck
Posted on Feb 12, 2008
  • 31 Answers
SOURCE: i need help hooking this up
"is the got two wires in the ground and remote turn on wie"
Can you be more specific about the wiring...where the two wires are connected to and where they come from, and I'll try to help you.
Posted on Mar 30, 2008
  • 149 Answers
SOURCE: MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Posted on Jun 04, 2009
  • 155 Answers
SOURCE: mtx thunder 6152 is getting way to hot and shuts
okay, first thing i would do is turn down your gain. Sounds like you are over working the amp thats wire your amp gets hot and shut off, it's going into protection mode. Is your amp enough for your subs. Some times not getting enough power to your amp might do this too. But if your subs wattage is way over your amp watts, you need to upgrade your amp. Also check your subs and see how the are wired up with the ohms, And see if your amp can take a 1 ohm stable load or how ever it's wired up at. hope this was helpfull.
Posted on May 13, 2010
Whattx thunder amp would or can go with Mtx thunder 6152 amp?
I can see were you would need the amp to be compatible with the deck but with another amp? the amp is amplifying a specific channel, front or rear speakers and for base only when the deck has a subwoofer pre out built into it. as for compatibility between the amps it would all depend on the sound you want and location and size of speakes will also play a part in that.
Mar 01, 2014 | Car Audio & Video
Is the MTX thunder 6152 r capable of 1ohm
its capable of a minimum of 2 ohms; the sticker on the bottom should say
Jan 22, 2011 | MTX Thunder 6152 Car Audio Amplifier
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
When i try to hook up amp no lights turn on.im pretty sure it works.how can u tell if its burnt up
first thing to do is smell it, second thing to do is to take the bottom covor off to visually check for damage, third is to bench test it with a car batter, a regualar 4 ohm speaker that you know works, and a cd player with rcas going into the amplifer, this is the best way, then if it works on the bench, it must be something with your wiring, bad ground, loose battery clamp, etc.
Aug 09, 2010 | MTX Thunder 6152 Car Audio Amplifier
Mtx thunder 6152 is getting way to hot and shuts its self off when it get really hot
May 13, 2010 | MTX Thunder 6152 Car Audio Amplifier
I just got a mtx thunder 6152 amp got it all hooked up its working but red light is on, should it be red or green?
http://www.mtx.com/caraudio/archive/NDM185.pdf .... go to this link for more help, it is the owners manual
Apr 24, 2010 | MTX Thunder 6152 Car Audio Amplifier
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
Aug 05, 2007 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
