Question about Home Security
Eircom phonewatch system battery low
Sensor battery needed replacing so I popped the fuse from the main control panel to stop it beeping while I located a new one. That's done now, but now the panel beeps every minute because the 'system battery is low'. How do I replace the system battery?
Kidyubyub
  • 143 Answers
SOURCE: Alert system battery voltage low (Beep Beep)
Bigbiggs is correct. Also, most newer BIOS have an option that states to Start up (BOOT) or Not Start up (NOT BOOT) on power failure. Because the battery is not keeping BIOS settings, this may be reverted back to Start up when power is applied. Check BIOS settings when you get tha battery situation sorted out.
Posted on May 13, 2008
  • 188 Answers
SOURCE: system keeps beeping that sensor 3 is low battery
Did you try a system reset? You should be able to bypass.
Posted on Aug 07, 2009
  • 3 Answers
SOURCE: battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
Posted on Sep 28, 2009
SOURCE: can not locate fuse box under instrument panel
I spent a good hour trying to find the "instrument panel fuse box". I almost started ripping the wrong stuff off. Think they could have stamped it to identify it a bit better?
You must open the door, it's right there on the side. It doesn't look or feel like it should come off (piece with a vent hole of sorts). You have to really reef on it, it does come off.
Probably get a little needle nose pliers for getting the fuses out now.
Posted on Oct 06, 2009
  • 54 Answers
SOURCE: one beep constantly
Most new smoke detectors work off of two power sources, electric and battery backup. The battery is used to power the detector if primary electrical AC power is lost. It would be a good idea to replace all detector batteries every two years or so. You'll access the battery by opening the unit, find out the type used and then purchase a replacement at your local store. Hope this helps.
Posted on Apr 16, 2010
KUDE60HXSS-DW is getting power but will not work-no lights/beep or response to cycle touch panel. Trying to locate fuse with no success
There is what is called the "triac-load fuse" on the main board, but it is not replaceable... I would expose the main control and look at the back of the circuit board for burns...
Nov 21, 2016 | Dishwashers
Hi i got a 2009 bentely continental gt went on vacation got back and batteteries are flat replaced them but car wont still crank
  • I have never done any Bentley work. However from what you are saying I would suggest locating the junction box under the hood. This is a relay and fuse box. Pop the lid and on the under side is the legend for the panel layout. Look for the main fuse as this fuse will stop everything. I also suggest you look for any relays marked for the "ignition." Sounds like one of the relays for the ignition of that main fuse are bad. For about any car I would start with this after replacing the battery.
  • There is always the possibility of this being the starter just went out too but this can be tested before replacing but check the panel box first.
  • If you have the owners manual you can look up the exact location of them as well.
  • Hope this helps.
Nov 02, 2011 | Cars & Trucks
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
I left my lights on, on my 2002 Suzuki Esteem and the horn was barely beeping. When I was getting a boost the postive and negative chords were placed wrong and it sparked on my battery. After that my car...
I hate to say it, but you will have to go one by one. There is a box under the hood on the drivers fender with fuses, and drivers side dash, just above the kick panel. Its faces down, has a black cover on it. I really hope you didn't burn you computer, but what I would do is take your owners manual and locate the MAIN POWER fuse. It will be a high amperage probably 50-90 amps, and most likely be located under the hood in that fuse box. Usually that is what blows if you have a power spike like that. Thanks.
Mar 16, 2011 | 2002 Suzuki Esteem
I need a fuse box diagram for a 2003 Ford Explorer Sport
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout- I think this is a good sticky candidate--
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
Oct 10, 2009 | 2003 Ford Explorer Sport
Westech 5000 battery low and i can't figure out how to fix it
There are 2 posibilities for having a low battery. 1) Your main backup battery for the control panel is low, or 2) You have wireless transmitters in your system that use small batteries and need to be replaced. To replace the control panel's battery look for a large metal box which is the control panel. These panels are normally located either in the basement or a 1st floor closet. Open the panel if you have a key. If you do not have a key take a pry bar and pop the box so it opens. Inside you will find an electronic motherboard with a black & red wire which is plugged into the battery. Grab a hold of the connector at the battery and wiggle/pull until the wire/connector disengages. Do the same for the other wire. Take the battery to a battery warehouse store and have them match it up. Be sure when reconnecting the new battery to plug the black wire/connector into the balck marked side of the battey and red to red. If you have a wireless system you will need to pull apart one of the transmitters & see the type of battery used. Replace all the batteries at the same time. They will last normally 3-5 years. The control panel's battery will last about 5 years.
Aug 25, 2009 | Home Security
Non stop trouble beeping every 30 on my simon 3 security system
Two separate problems: Sensor failure and phone communication failure. Most likely, you've not been hooked up to a phone for a while but the system didn't know until it tried to transmit to the monitoring center that you removed a cover on a sensor.
I can tell you how to turn off the panel beeps, "beeps" not only includes the trouble beeps that are driving you crazy, but also the beeps letting you know it's counting down, either when you've just armed it or when you come home right before the alarm sounds.
Open the cover and enter your code using the red numbered buttons inside there. It doesn't beep when you press buttons, so press them well. When you've done it right, it will tell you to choose from the Start Menu. Choose "DELETE". Then, from the Main Menu, choose "OPTION #". Then press DONE. You have now turned off beeps. You haven't fixed anything and that sensor still isn't working but it's not beeping to get your attention now. Press SYSTEM STATUS two times to hear it tell you what's going on.
To turn beeps on again, open cover, enter code and choose ADD > OPTION # > DONE.
Nov 16, 2008 | GE Security Simon 3 Wireless Home Security...
System Low Battery Alarm
You can silence trouble beeps by arming and disarming the system or by pressing status button; however, trouble beeps resume after 4 hours if the trouble condition as not been fixed. You can turn the trouble beeps off in the programming option 40. This should be done by your security professional because any mistake you could change other parameters in the system and the system may not work correctly. Hope this helps
Aug 19, 2008 | GE Security Simon 3 Wireless Home Security...
Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Jul 19, 2007 | Dacor ECS130 Epicure Electric Single Oven
Home Security Logo
280 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
