Question about Actron CP7677 - Auto Trouble Shooter
CP7677 wont read ohms
Continuity works on the meter but will not read ohms, replaced battery and fuses are good.
    Sergeant:
  • 249 Answers
Make sure the test leads are correctly inserted into the proper sockets, select the range that is higher than what you are testing, e.g., 240ohm, set it to the 2k range. If you are not getting a reading, (open circuit / infinite / "1.") click up one range. You can download the manual from their website if you don't have one.
http://www.actron.com/publish/2004/06/07/pdf_english_16155.pdf
Posted on Apr 16, 2014
I have a 1994 Polaris SL750 jetski that will not turn over
Have you checked that the switch is switching (i know you said you've checked it) by putting meter in ohms scale and looking for open circuit and then low ohms reading when switch closed for instance 0.2ohm...0 ohm when open?
Dec 30, 2017 | Motorcycles
How do I test fuses?
With voltage present, get a voltage meter and put a probe on either side of the fuses. You should have 0 volts if the fuse is good. You will have supply voltage if the fuse is burnt.
If you check without power pull the fuse and use audible continuity or the ohms setting on the meter. You should read 0 ohms if the fuse is good. If it reads O.L. the fuse is burnt.
Mar 03, 2015 | 2004 Chevrolet Chevrolet TrailBlazer LS
Heater and windows quit working ,how to check closed fuses,or should i say incases not clear fuses
use a multi meter set on ohms (continuity) and put a lead to either blade/end of the fuse If the meter reads no ohms then the fuse is good . If no reading then the fuse is shot.
Dec 19, 2013 | Cars & Trucks
Dryer drum works but does not heat. Everything else works. I have checked the fuse and I have made sure it is not on air dry.
THERMAL FUSES MAY BE THE CAUSE OF THIS In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element. Follow the diagram below to see how to check the continuity of the switch, and look closely at the switch to see a fairly close idea of what you are looking for, ok
OR it could be a thermostat.
Cycle and safety thermostats-read them with an ohm meter. Should show continuity .
or lastly, it might be
the Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
IF you do not have an OHM-METER, then you can check these issues by following the directions below:
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Do not forget to rate this answer!!
Jan 24, 2011 | Frigidaire Electric Dryer
My roper electric dryer was working fine then i put a load in and it wont turn on. Yes it is plugged in. Do you have any idea what it may be?
Yes,I have a good idea.
First,take your volt meter and verify 220 volts are in fact coming to the dryer terminal block.
If it is,unplug the dryer.
Remove the rear panel.
Set your volt meter for ohms.
Unplug the thermal fuse located on the left of the main exhaust vent.
It is 1 and 1/2 inches long by 1/2 inch wide and white in color.
Touch the 2 meter leads to the 2 terminals on the thermal fuse.
No trading is a bad fuse.
Replace it.
If the fuse gets a reading it is OK.
Then,open the top lid from the cabinet and check the door switch for continuity.
If there is no continuity,replace the door switch.
Sep 14, 2010 | Roper Dryers
Where is the horn relay located found fuse horn will not cut off unless u take fuse out drawing down battery trying to check to see if relay bad cannot find it
The horn relay is located under the hood with the fuses. look inside the lid when you remove it from the fuse/relay box and it will tell you where the relay is located. To test the relay use an ohm meter and connect one end to 87a and the other end of meter to 30. there should show continuity. then check between 87 and 30 and there should be no continuity. if all of this checks out then check resistance between terminals 85 and 86. It should read 70/80 ohms. if not replace relay. If it shows good then connect a jumper wire between battery positive terminal to 86 and a ground jumper to 85 terminal. You should hear a click or clicking sound. If not replace relay. hope this will help you.
May 11, 2010 | 2004 Dodge Ram 1500
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
Jan 09, 2010 | Kenmore Dryers
The dryer is not heating
Hello there here is a list of things to check
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
Jan 09, 2010 | Dryers
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
The left front radiant heating unit does not heat. All other are working fine
Check the heating unit with an OHM meter.
This is not rocket science. An OHM meter will check for continuity (a break inside the heating unit). Any appliance parts place will have a meter, even Wal-Mart. The meter can be set for AC/DC/ OHM's, Volts, etc.
Set the meter on OHM and touch the two leads on the meter together and the meter arm should move. Now, take the heating unit out of the range and touch one lead to one end of the heating unit and the other lead to the other end. If you get a reading then the unit is good and the switch must be replaced.
No reading, replace the heating unit.
Some parts require knowing how many OHM's but in this case any kind of reading will show there is no break inside the unit (continuity).
You can check extensions cords this way or set it on volts and check batteries. Everyone should have one.
Dec 17, 2008 | GE Profile JSP47 Electric Single Oven
Actron CP7677 - Auto Trouble Shooter Logo
176 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
