Question about Astak ActionPro 1080p HD Video Camera with Waterproof Case CM-7000
Cant open actionpro cm-7500 files on my computer
Hi I took this out today for my first recording. When I got home I plugged it into my laptop to see my recording. This is when I started having issues. Firstly when I connected to the laptop it auto plays with windows media player then froze so I close down the program and started again. Same issue but this time the camera turned it self off. So I left the camera on charge until the red light turned off and now the camera wont turn on at all. I took out the battery and put in back in and the camera turned back on so again I connected to the laptop and once again it windows media player pop up and froze! so this time I cancelled auto play option in my control panel and tried opening within file explorer. but even that crashes when I click on the mp4 file and I cant even copy the files to my desktop.
My recording has just disappeared after looking with zero size.
If you can listen to the recording, on the player, it must be a different format. Play the recording back whilst recording on your laptop, if your laptop has no internal microphone, buy an external one, for recording.
Dec 03, 2013 | Creative Labs ZEN Neeon 2 MP3 Player
I bought one of these today and there are NO instructions with it at all, other than to simply plug it in. That doesn't seem to work. Nothing about how to download the records you want on it. Not all of us...
Hi!
If you are using windows all you need to do is plug that in on any of the USB ports that you have. Wait for windows to identify or install the device. It would only install the driver once. Everytime we plug that in you will hear a couple of tones that signify that your device has been plugged in and identified by windows. What you could do is open up my computer or your windows explorer and you will find a new drive there which is your removable drive. just double click your drive and you could just copy and paste your files onto there for storage. you could then open your files directly from that device or you could copy them to another computer.
If you have any more questions feel free to send them and we will be glad to answer them for you.
You have a great day.
Feb 11, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
There 2 surboard in my home but one is going too slow there both in seperate computers but i think we got home group connection not sure
open the internet explorer2_bing.gif on the addresss bar put 192.168.100.1 then go to hack add on file adress file d11_m_speedtierextreme2_c01.cm
then on ip server file put 68.87.68.35 the press change id then unplug the modem then plug it back the speed should be back
Mar 09, 2010 | Arris SURFboard SB4200 Modem
When I try to record vinyl records it gets no
Press STOP to stop recording.
Click "save" and save the recording to a file in your "My Documents" folder.
Open your "My Documents" folder.
What is the "size" of the file?
Click with the SECOND (usually the RIGHT) mouse-button on the file, and click 'Play' (with Windows Media Player).
Does it play?
Does Windows Media Player show the correct length (minutes:seconds) for the recording?
Nov 09, 2009 | Sony Sound Forge Audio Studio 9 Full...
Cant open or view folders on computer
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Mar 01, 2009 | Olympus VN-120 Digital Voice Recorder
Vn-120 cant get it to work
12. Click Next
Mar 01, 2009 | Olympus VN-4100PC Digital Voice Recorder
Cant get mp3 files from my marantz pmd620 to play on my mac
Well, try copying them to a folder on your computer. Also, make sure that the files are not proteced with DRM. If these fail, open iTunes. Select all of the MP3 files and drag them into your library. That should fix it.
Feb 04, 2009 | Marantz PMD620 MP3 Player
Sony IC Recorder (ICD-P620)
  • I got this recorder for college. i read up on it to make sure that it works for vista home. It said it did so i opened it, know i couldn't return it if i opened it because i got it from the college book store.So it didn't work so i was very upset so i called sony to see what the problem was so the told me that all their products only work with a 32 bit operating system from vista and i have a 64 bit operating system there for it wont work for my computer and i cant return it and i cant get a refund so now im stuck with this junk i cant use. anyway to check if you have a 32bit or 64 bit operating system go to you start bar and right click on the computer button on the right click properties it should tell you there what you have if it said 32 bit i would call sony and have it repaired if you have a 64 bit take it back to the store you got it from it wont work
Oct 06, 2008 | Sony ICDP620 Digital Voice Recorder
How increase my mic volume
a) to hell with calling india, they are as dumb as bush is.
b) click start > accessories > entertainment > volume controls. when the volume controls open, click on file (drop down menu) then select recording, then click ok. when the recording volume controls come up. select microphone as the default recording device, and make sure the mute box is not checked. slide the volume control slider most of the way up.
c) if you are using yahoo's call-out, run the audio wizard in yahoo messenger before making call.
d) plug your microphone into other 3.5 mm jacks on computer, and use window's sound recorder to see if the computer is picking up audio through the mic.
e) make sure your microphone's mute switch is not turned on (if applicable).
Jun 23, 2008 | Acer Aspire 5610 Notebook
Transfering a vhs to a dvd
Hi jh1014,
If the disc is not playing on your home DVD player, it is possible that it was recorded in a format your unit does not support.
Your friend’s DVD recorder most likely recorded the DVD in a format readable by the player in which you watched it successfully.
Refer to your product manual for more information on which file formats your DVD player supports.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 17, 2008 | Televison & Video
Astak ActionPro 1080p HD Video Camera with Waterproof Case CM-7000 Logo
Top Astak Video Cameras Experts
Are you an Astak Video Camera Expert? Answer questions, earn points and help others
