Question about Dell Computers & Internet
Inspiron 7120 wiring diagrams
It worked a couple days ago, and I updated everything for windows and it was fine. Now it looks like maybe the battery is dead? Even though I push the button on back of battery and it's lighting up. So, there is that unconnected wire under the hinge on the right side by monitor. Also, you push the power button and the HD lights up for a second, then fans stop, then the battery light goes on.
  • 1 more comment
  • D. Mullen Apr 16, 2014
    I took pics of loose wire, not sure if I can attach here though.
    option 1 won't work as the computer won't power up, option 2 had nothing to do with my monitor (just had it fixed) and option 3 I tried doing that several times and nothin. :(
  • D. Mullen Apr 25, 2014
    Well, no responses so I just have to save some money and will get a new battery.
SOURCE: Broan Allure QS3
The Problem is the wiring. Take the 2 screws retaining the metal plaque off underneath the filters. You will see the wires leaving the motor going into a "molex" plastic connector which connects two another set of wires going to the control board. Check to see if the wiring colors match from side to side of plastic connector. Ive only seen it happen once but it was exactly that. I do service calls for broan & Nutone
Posted on May 14, 2008
  • 1861 Answers
SOURCE: no dome light on tacoma
The dome light gets 12 volt battery power at all times. The door switch, when the door is opened, allows the current to flow to ground, and completes the circuit. The door switch allows the ground to be made. Measure for 12 volts at the wiring connector, and measure for direct short at the ground wire, with the door open. The Ground wire is white with a black tracer.
Posted on Feb 27, 2009
  • 70 Answers
SOURCE: Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Posted on Mar 17, 2009
SOURCE: There is no red.
It could be cable connection. if your using a VGA cable <15 pin> some times a wire breaks inside or is not making good connection to the vid card. It WILL drop one color. so in a pure red area it comes up black but the screen overall will look off or odd colored. The reason for this is the Blue and Green will still be there mixed and no red so the color balance is gone.. I have had a monitor do this. had to final replace it due to loss of red.. this is a uncommon but NOT rare problem in VGA cables . <in very rare cases the connector on the vid card breaks connection on the red/blue/green line so it ends up the card not the monitor or cable
Posted on Jul 19, 2009
  • 558 Answers
SOURCE: Power light comes on and goes off and machine is dead
The Motherboard is bad but before you buy one.Try this Remove the memory, cd rom,hard drive battery, power adapter. Press and hold the power button down for about twenty .Replace the memory only,power up if you get the same result the motherboard has to be replace
Posted on Sep 16, 2009
I have a 1999 yamaha kodiak 400 4x4. I bought it a couple of weeks ago and everything worked fine....I've been riding it about every day and a couple of days ago, I hopped on it and the speedometer and...
Have a look up under the dash and see if the cable drive has fallen away. If not undo the cable and try pulling out the inner. If it comes away short then its busted. See a parts house for a replacement.
Dec 29, 2014 | ATVs
Power window circuit on '93 Bravada
check for battery voltages then if it is 12 v above pull out the the power window motor and test directly to the battery f the motor is working f it is working check for power supply maybe fuse blown or the main switch is malfunctioning!
Jun 30, 2012 | 1993 Oldsmobile Bravada
My battery was bad, so I had it replaced and the car worked fine for a few days. One day while out running errands I went to start the car and nothing happened. No sounds, etc. All of the lights work...
Sounds like you have a dead battery again. Who install you battery? Did they check out the charging circuit on your auto. If a professional mechanic installed your battery then have him check everything out; such as, cleaned battery terminals, the ground strap is solidly connected the body, charging system is working. If a professional mechanic didn't install you battery.
Remove the battery from the car/truck and have it fully charged. Clean the ground and positive terminals with wire brush until the lead is bright and all the corrosion is gone. Clean the battery terminals until the batter terminals are bright. Get a couple anti-corrosive felt disk---they look like two big felt washers, one red (+) and other is black (-). Insatll the battery and make sure the terminals are tight. Start the car/truck and while the vehicle is running take a voltage test across the battery with multimeter, volt meter, etc. The voltage across the battery while the vehicle is running should be 13.8V to 14.1 volts. If not, Have the alternator check out!
Like you said you have had everything check out. Check it out again. If everything check out again then there is a internal component, wiring shorted which pulling current the battery and could drain the batter of current within a few days.
If you are using your car for a few days to running errands. You car will run on the battery with no charging cycle working. Once the battery voltage falls below a certain voltage point the computer will only limit certain electrical components work, door locks, maybe one window and this is iffy! The reason why you can't get the transmission out of park is the locking solenoid that operates with the brake switch will not function. This function is a safety procedure that is Incorporated within the vehicle design. . GB...stewbison
Aug 23, 2011 | Chrysler 300 Cars & Trucks
Paint tool sai doesnt recognize the tablet
i have the same problem maybe update the driver
Mar 28, 2010 | Computers & Internet
Dell inspiron 1440 broken
Maybe you didn`t get all of the updates and you need to go back and do all of them.
Go to START, ALL PROGRAMS, WINDOWS UPDATE and complete all of them, restart when it tells you to and do it again and again until ther are no more updates.
Or you have the choice of removing the updates you complete prevously, if you choose to do this then this is how you do it in Windows 7
Let me know how everything turns out..
Dec 23, 2009 | Computers & Internet
My dell inspiron 1525 microphone does not record.
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
Mar 15, 2009 | Dell Inspiron 1525 Notebook
Power door locks and windows
The answer to your question is maybe. Get a couple of switches from a junkyard (my guy gets $5.00 each) and try them. Here's why: I have no less than five different wiring diagrams, and none of them make any sense at all (been doing this stuff a really long time) I keep a good switch handy to check my jeeps when one gets wierd on me...even so, my 93 passenger window works with the key off, none of the others do. Stopped trying to figure it out a long time ago, but would really like to meet the guy who designed this stuff!
Feb 22, 2009 | 2000 Jeep Grand Cherokee
No power when I try to start bike, just a click…
Check the battery connections. Remove, clean and reinstall them. You probably had them off doing the wiring and they aren't making a good connection now. Always remove the negative first and install it last.
Nov 20, 2008 | 2001 Harley Davidson FXDL Dyna Low Rider
Can't get my window up!!
remove the door panel, and take a wire and attach it ot the body of the car, and another one to the positive battery post, this will roll the window up for you, then you will need to replace the window motor.
Jul 01, 2008 | 2000 Ford Expedition
Computers & Internet Logo
46 people viewed this question
Alun Cox
