Question about Dryers
I pur. Model #WED8500BWO Serial #M345 28151 New 3-5-14 On4-14-14 the check vent light came on. I checked the entire system. No blockage of any kind was found. Heck, it is only 6-weeks old and it is just my Wife and I.We have not used the dryer for fear of damaging something. All installation is per instructions as well as hardware.Please Advise ASAP. We have Purchased an Extended Protection Plan.
  • 184 Answers
SOURCE: Kenmore Elite H3 Dryer taking longer than normal to dry clothes
EVEN THOUGH THERE IS WARM AIR COMING OUT THE EXHAUST, IT STILL MAY HAVE A RESTRICTION IN THE DUCT WORK. DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER FOR ONE LOAD OF LAUNDRY. IF IT DRYS THE CLOTHES O.K., YOU HAVE A RESRICTION SOMEWHERE IN THE EXHAUST.
NOTE: DO NOT USE VINYL OR PLASTIC DUCTING. VINYL IS NOT U.L. APPROVED. PLASTIC PVC WILL ALLOW CONDENSATION TO PUDDLE INSIDE THE PIPE CAUSING A
COMPLETE RESTRICTION.
Posted on Mar 31, 2008
  • 3422 Answers
SOURCE: Tromm DLE5955 dryer less than
HI,
Clean the lint screen/filter before or after drying each load of clothes. If clothing is still damp at the end of a typical drying cycle or drying requires longer times than normal, this may be a sign that the lint screen or the exhaust duct is blocked.
Please don't forget to rate or accept the solution.
Posted on Jun 08, 2008
centralhigh
  • 260 Answers
SOURCE: Whirlpool Dryer Model # LE7680XSW1
David,
You have a pretty old dryer. Replacement is recommended because new dryers use less electricity and more than make up for the price with the savings on your electric bill.
However, if you still want to use this dryer, you will need to replace some internal switches. In order to guide you through that I recommend you use our premium service.
If you need to find a local repair service, please type your zip code into our repair service search engin located on our site.
Good luck,
CH
Posted on Jul 30, 2008
SOURCE: Problem with Kenmore Dryer HE2
have you gotten any error codes?
Posted on Nov 05, 2008
  • 583 Answers
SOURCE: whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Posted on Mar 03, 2009
Whirlpool dryer wed8500bwo
Hello Jean;
My name is Peter. I am a retired field service appliance technician.
1.) Did you purchase the correct power cord. There are 3 and 4 terminal cords.
2.) There is a green ground wire. Did you ground or connect this wire to metal?
3.) Did you check your breaker box? To make sure the breaker did not fail?
I wish I were there to help you.
Peter, Baltimore , Maryland, Phone 443-306-1362
Dec 06, 2014 | Whirlpool Dryers
Keep getting warning "check exhaust" on a new gas dryer. All exhaust is clear. What's going on?
The CHECK VENT duct blockage sensing system detects and alerts you to blockages in the duct work that reduce exhaust flow from the dryer. This light does not indicate any problems with your dryer. If this light blinks, it indicates that your home's exhaust system/duct work has a serious restriction
Every time the dryer is turned on, the CHECK FILTER LIGHT WILL BLINK, as a reminder to make sure the filter is clean. Always make sure the lint filter is clean before starting a new load; a clogged lint filter will increase drying times.
The Kenmore Elite dryer has a sensor that detects poor exhaust venting, and when it does, a light flashes on the control panel. This warning light does not include a mechanism to stop gas flow, but if it is allowed to flash for an extended period, poor venting may cause the dryer to overheat. As a result, a fuse might blow and disable the gas valve or ignitor. You can prevent this by diagnosing the reason for the flashing indicator light as soon as possible.
In many cases, LINT has built up somewhere in the exhaust pipes.
Check under the lint filter. Pull it out,look inside the slot it fits in, and clear all lint from this area.
Is it possible you have used the WRONG VENT MATERIAL?
Check your vent to make sure it is 4 inch rigid or semi-rigid metal ducting. If your venting is plastic or flexible foil, replace it before using the dryer.
Check your vent hood outside. You may have a restricted or damaged vent hood. It must be clean and free of lint buildup. Check the damper and make sure it opens fully and easily and is free of lint.
I know you said you have no elbows, but I have posted the pipe run lengths with and without elbows. Keep in mind this is with 4 inch rigid or semi rigid metal ducting.
Measure the length of your exhaust system and count the elbows. Use the chart below to see if your duct is too long. If it is too long, have the duct routed to another location that is within the venting guidelines.
0~90 degree elbows=65 ft of 4 inch rigid metal duct.
1~90 degree elbow=55 ft of 4 inch rigid metal duct.
2~90 degree elbows=47 ft """"""""
3~90 degree elbows=36 ft """"""""
4~90 degree elbows=28 ft """"""""
You should always use duct tape or metal tape on all joints, NEVER USE SCREWS, as screws capture lint inside the pipe.
One more note. Lots of people overlook the fact that fabric softeners can build up on the lint filter over time. This buildup can restrict the airflow through the filter reducing dryer efficiency and lengthening drying times. After removing lint, if the filter looks dark or dirty when held up to the light, follow these steps to clean:
Use hot soapy water and a stiff brush to clean
the filter.
Make sure the filter is completely dry before
reinstalling it and using the dryer.
NEVER operate the dryer with a wet lint filter.
Oct 29, 2014 | Kenmore Dryers
2000 Ford Expedition My Expedition (4.6L V-9 2WD) has had an intermittent problem of cutting out. The Check Engine light was not coming on - so I figured it is not a misfire. It drove just like it had...
Continuous Memory Diagnostic Trouble Code (DTC) P0446 or P1450 indicates that Self-Test has detected the Evaporative Emission Control System has excessive fuel tank vacuum. Also, a DTC P0446 indicates a vent control malfunction.
Possible causes:
EVAP canister purge outlet tube (EVAP canister purge valve to EVAP canister) blockages or kinks.
EVAP canister tube (fuel tank to EVAP canister) blockages or kinks.
Fuel vapor elbow on EVAP canister contaminated.
Restricted EVAP canister.
Canister vent (CV) solenoid stuck closed (partially or fully).
Plugged or contaminated CV solenoid filter.
EVAP canister purge valve stuck open.
Fuel filler cap stuck closed (no vacuum relief).
VREF circuit open in fuel tank pressure (FTP) sensor.
Damaged FTP sensor. (fuel tank pressure)
Check for kinks or bends in the fuel vapor hoses/tubes (EVAP canister purge outlet tube and EVAP canister tube).
Visually inspect EVAP canister inlet port, CV solenoid filter and canister vent hose assembly for contamination or debris.
Check CV solenoid filter for blockage or contamination.
The common things I've seen are are mud in the canister and the canister vent solenoid being shot or the wiring to the canister vent solenoid being torn off. The resistance of the solenoid should be 48-65 ohms..
Pick up a Chiltons book and will give you a diagram of where exactly you find the canister. They are like $15 at any auto store. Good luck
May 22, 2011 | 2000 Ford Expedition
Not drying properly.Also stpos in middle of cycle.
You may have a partial blockage in the vent due to lint buildup. Also, check the lint trap to be sure it is clear. To check the vent pipe you must pull the machine away from the wall so you can get behind it. then loosen the clamp holding the vent tube or hose to the back of the dryer. Using a flash light check the back end of the dryer and the entire tube plus check to see what is going on outdoors where the dryer vents to the out-of-doors
Feb 24, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I am getting the pressure switch blockage and the three red light code. Replaced the pressure switch and still does not work
Hi, the pressure switch won't close error isn't always caused by a defective switch. Occasionally, there really is a blockage in the vent system and that is why there is a pressure switch. You should check for such a blockage, usually caused by a smashed vent cap or spider webs in the vent pipe. Good luck.
Jan 11, 2010 | Goodman Heating & Cooling
Dryer became very hot and then shut off and will not turn back on Maytag model MDE9420AYW
Refer to part #11 on diagram #4 to see where the thermal fuse is located. The thermal fuse and the high limit thermostat must be replaced.
You must find and correct the vent blockage problem or you will blow out the new parts.
Check the vent system inside the dryer. Check the connecting vent from the dryer to the wall connection. Check the through the wall connection. Also check the blower wheel attached to the motor. It could be stripped and slipping on the motor shaft.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45466&diagram_id=647881#d647881
Jan 01, 2010 | Maytag Dryers
I have a maytag dryer, fairly new and not used that much. It is overheating and shutting off. This weekend, we took it apart and found sand in the lint trap and cleaned it all out. The vent is clean too....
check the entire exhaust system for blockages. check all components that make up the entire exhaust system. this includes the vent hose and blower assembly as well. if the exhaust system if free of obstructions, this will confirm a faulty High limit thermostat. replace this failed component asap. During the exhaust check, make sure when the unit is drying that, it is blowing at a high rate. you should feel a good forceful air flow out the vent. if its weak, you will need to clear the blockage.
Jun 15, 2009 | Maytag Dryers
My clothes are not drying fast enough
Hello. I was the last person to post with problems with the Miele T1403 Electric dryer. Just wanted everyone to know I solved my problem and this could solve yours as well. To reiterate I too was frustrated with clothes that would not dry. I could feel heat but the vent/filter light would keep beeping and evetually turn off my dryer. The result would be damp clothes especially towels!! I had a certified Miele dealer come in and check out the machine. This was after I completely cleaned out the lint trap the inside of the machine, and the duct connecting it to the wall. Well they looked at everything and determined nothing was wrong with dryer and I had done a great job cleaning it. Armed with this info I was referred to a company that specializes in cleaning the entire interior duct system of the dryer(Not just the lint trap, inside of machine, and connector tubing). They came today and disconnected the machine again went into the attic and used a shopvac type of machine to really clean the entire duct system. Not rocket science but viola problem solved!! You could probably do this yourself if you have a shopvac with a long attachment (depending on how many bends your system has). The machine is working great and now I know to clean the system at least once or twice a year. I was told that slow drying clothes, extra moisture, machines that are very hot to the touch,etc. can all be symptoms of a blocked vent. By the way a blockage can be a fire hazard. This solution is a lot cheaper than a service call or worse getting a new dryer. I wouldn't listen to the hype about European dryers like Miele or Bosch not drying clothes all the way-could just be a blockage. These brands are very good at shutting themselves off when they get hot (which is a good thing).
Aug 24, 2008 | Dryers
Check engine light
DESCRIPTION
A restricted or blocked evaporative emission (EVAP) vent path is detected by the control module monitoring the fuel tank pressure (FTP) during normal operation. The control module commands the EVAP vent valve OFF, or open, and the EVAP canister purge valve ON, or open. The fuel tank pressure should remain low as vacuum is drawn on the EVAP system. If the vent path is blocked or restricted, the vacuum level will increase and DTC P0446 will set.
DIAGNOSTIC AIDS
An intermittent Condition could be caused by a damaged EVAP vent housing, a temporary blockage at the EVAP vent valve inlet, or a pinched vent hose. A blockage in the vent system will also cause a poor fuel fill problem.
May 24, 2008 | 2002 Chevrolet Avalanche
Dryers Logo
105 people viewed this question
Top Dryers Experts
