Question about Refrigerators
No temp lights on fridge or frezer panel.light on in frezer not in fridge
Fridge was working fine. Door of fridge left open few minutes it seems like fridge has turned off. Is there a reset button. freezer light is on but no light in fridge compartment. Temp panel lights not on. Power to fridge is on.
    Sergeant:
  • 249 Answers
Try cycling the power. Switch of the fridge at its isolator (or wall socket), leave for 1 minute and switch on again.
Consult your owner manual for guidance.
If still under warranty, contact your dealer.
Posted on Apr 16, 2014
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
Frezer works fine but the fridge is not ayy ideas
Hi, Sorry to hear you've got an issue with your fridge in the middle of summer. Do you have a dual control for seperate temps? If you've already done that then see below,
So heres how things work, Refrigeration is a by-product of your freezers normal process.
Meaning that air is circulated between the two to chill the frige portion. Its very likely that either the fan has quit or the circulation vent and /or blades are blocked by ice.Try holding the door open and pressing the button for the light and listen for the fan running. If you don't hear it, it's time to defrost the freezer and clean out the fridge. You will also have to disassemble the panels in the fridge, (unscrew) and inspect every thing you can get your hands on to clear up the possibilities.
Jul 27, 2009 | Refrigerators
Refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Subzero door left open - now acting strange
You have probably already figured this out, but if the door is left open there is a sensor that will turn the lights off to keep the fridge from overheating. After you close the door and let it sit with the lights off for 15 minutes or so, the sensor will cool and allow the lights back on. If the temperature reading in the window is ok and does not say "service" or "vacuum condenser", then you should have no more trouble.
May 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
