Total missfunction of player MITMP32 4Gb (Mitone Sporty MP4 Player)
How can I re-format this player software? The problems are: - When I choose Spanish as a Language it works in Dutch. - I can never play yhe music O want to listen, instead of this is allways going to the same song without possibility to choose another one.
SOURCE: MITONE MP3 player software files are formatted
If a player like this http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610 , there are several clones of the Chinese goods. Firmware on the Russian here (English supports) http://ftp.roverbook.com/RoverMedia/Aria_Q7  there two different versions of firmware for the assembly player (one can work with bugs)
Methodology firmware:
1. Disable USB cable, turn off player.
2. Holding down "M" connect the USB cable.
3. The menu select 3 - y para (other then USB disk), clicking the right analog stick.
4. The system will appear logical disk 2. First at 16 mb, second - remaining FLASH memory.
5. Copy invested in this archive 5 files on 16 - MB removable disk (all except reame.txt).
6. Turn off the player through the safe extraction devices.
Posted on Mar 10, 2008
SOURCE: MP4
I'm having the same problem. I know my files are on my mp4 because it says there is only 2% disk space left...i have a Mp4 Digital Audio/video player with built in speakers...it was working fine but i think i may have acidentially deleted something i shouldnt have and i have no idea how to fix it. It also says empty disk when i go to play a song....but i know they are there.
Posted on Apr 11, 2008
SOURCE: I have a Mitone MP4
hi all just fixed the languae prob on the mitone player as follows
hit settings icon at the bottom right of screen- box will be ticked
-hit the sixth box on the screen-
 tick box
then there are 3 optionsboxes  hit the first one it is for language settings-then hit the third box it says english and happy days
 hope this helps you
ttfn,
Tracy T
Posted on Apr 25, 2008
  • 4 Answers
SOURCE: cant get music
I have this nasty little player too, and it has caused a lot of grief including suddenly zapping all the files I'd put on it inluding the stuff that Laser pre-loaded into it. Be warned, this player is very prone to errors so it can't be relied on.
If it is under warranty you can take it back. Otherwise you will probably have to look at reformatting the player. Not a big job, but before you do this, copy everything off it onto your hard drive.
Reformat by connecting the player to your computer and finding it under My Computer. Right-click on it's name, and select 'Format'.
Format it in Fat32 which will probably be shown as the default in the Format window.
When it's finished you should be able to reload the player with a bit of music, then disconnect the player and test to see if all is ok.
Laser have a website if you google it, and a simple Faq. Writing to them about the problems with the player and seeking some solution brought no response for us. Good luck. When it's working you can forgive it the grief it causes.
Posted on Jan 15, 2009
SOURCE: downloading and playing files
Here is the link to the Mitone company.http://www.szimp3.com
Dr. Fawaz
gm@tekvalorg
Posted on Feb 11, 2009
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
I have just bought a new sansa clip. i have successfully uploaded music to the the player and i can hear it well. now when i try to access the player through the computer i cannot access the music and...
Hi, are you sure the computer is recognizing your player?...if not....
4. Power issue.
- Run the hotfix.
Hope it helped ..
Have a nice day..
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
In my walkman nwz-e344 i have downloaded several videos to my walkman but none of them but the pre loaded videos appear. i hav tried to convert these files to wmv but even after converting the videos do...
I had similar problem that was solved by Total Video Converter software, download its trail version by clicking that link and convert video files in to mp4 format that will get playback in this player.
I select Zune Video option in Pocket Player selection that works great for me.
Click HERE to download a sample video song that is converted as mp4 format by Total Video Control software and it works great in my Sony player.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 15, 2010 | Sony Walkman NWZ-E344 Digital Media Player
What is the best program to use to put movies on my player?
As for me, i all through use Daniusoft video converter suite to convert various videos even Movie DVDs or HD videos to sony walkman-friendly format, and then put them to my Sony Walkman Video NWZ-S616F MP3 Player for watching ...
Jan 06, 2010 | Sony Walkman NWZ-S616F MP3 Player
I have mitone mitmp25 mp4 player When i connect it to pc, it shows 3 folders sls.dir playlist & mic.dir Where ould i copy mp4 files in thesefolders? I tried copying in every folder but the player...
Mitone MITMP25 plays only videos in MTV format, so you should use the software included to convert all videos into MTV format before you can play those. See page 21 in user manual :-)
Jul 02, 2009 | Yifang Digital Easy Mp3 EM01 MP3 Player
Mitone MP4 Player 4GB MITMP22 - software disck empty
MITONE MITMP22 4GB MEDIA PLAYER PLAYS RMVB FILES
TO CONVERT TO RMVB FILE USE WIN AVI (AVI TO RMVB)
ONCE YOU HAVE THE WIN AVI PROGRAMME THEN YOU WILL NEED THIS EXTENSION FILE (HelixSDK0715 win avi rm extention file) AND CHOOSE THE SIZE OF FILE TO SUIT YOUR SELF IN ADVANCED ONCE YOU HAVE SELECTED RM
Feb 16, 2009 | Kenwood KDC-MP4028 CD Player
Downloading and playing files
Dr. Fawaz
gm@tekvalorg
Sep 29, 2008 | Philips SA3115/02 1 GB Flash audio video...
MP3
I bought a MITONE FLASH MP4 DIGITAL PLAYER. I am downloading files from internet sites in mp3 format but am not managing to listen to them on my Mitone though it seems to be playing them. maybe i dont know how to use it yet. any suggestions please?
Jul 29, 2008 | Sony Write-Once Recordable, 30 spindle...
Need firmware for MiTone MITMP20
Jan 22, 2008 | Apple iPod shuffle MP3 Player
Jan 08, 2008 | Yifang Digital Easy Mp3 EM02 MP3 Player
37 people viewed this question
 Grubhead
Grubhead
