Question about Duplo Dp 203
Duplo dp203 not feeding paper
Duplo 203 not feeding paper
Paper jam
Duplo and Karagatan were early forms of Philippine drama.The Duplo was a poetic debate by trained men and women in the ninth night, which is the last night of the mourning period for the dead. The Karagatan was also a poetic debate like the Duplo, except its participants were amateurs. Both were held in homes and their theme was about a ring that fell into the sea.
Jul 13, 2013 | Brother MFC-J410W Wireless Compact...
Duplo dp-205A scanner open problem
duplo dp-203 problem scanner open
Feb 25, 2013 | Office Equipment & Supplies
I have an Emerald 203 When I hit the presser foot, the wheel goes round and needle moves up and down but the material does nt move
it sounds like the feed dogs are not working, if you have a manual
check and see if there is a lever to move the feed dogs up and down
and see if lever will move the feed dogs, if that lever doesn't then
the feed dogs will have to be checked.
here is a link for a manual if you don't have one
http://www.scribd.com/doc/104663888/Husqvarna-Viking-Emerald-183-203-User-Manual
Dec 14, 2012 | Husqvarna Sewing Machines
The printed page comes out creased from the top left of the page to the bottom right.
Download this manual >> http://www.mediafire.com/?i0y9iqnqu79ppcj Go to page #203(6-15) Paper Feeding problems (wrinkles or creases) and follow the troubleshooting steps.
Note: PDF manuals require the Adobe Acrobat Reader for viewing and printing. http://get.adobe.com/reader/
Sep 03, 2011 | Brother HL 5140 Laser Printer
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
Duplo DF-520 Error Code
you will find it in the operation guide. i uploaded the pdf copy here: http://www.mediafire.com/view/?7wvzv3jqwcyga1g
Jan 15, 2010 | Office Equipment & Supplies
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
We have a Duplo 43S copier. Everything seems to
The problem was that a regular sheet of paper had somehow become stuck to the drum and become overlaid with ink so that we did not see it until we got more light on the subject.
Aug 19, 2009 | Office Equipment & Supplies
Duplo Dp 203 Logo
20 people viewed this question
Top Duplo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
