Siemens s14-44 washing machine door stuck - Washing Machines
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Assuming its stuck because its not emptied propperly.remove drain hose from rear and with a bowl or large pan hold the hose at ground level.it will then drain,it doesnt need to be plugged in.but when u switch on you ll prob hear a clic.it should now release
Posted on Apr 16, 2014
kjmac
  • 97 Answers
SOURCE: washing machine
is all the water out of the machine if not the door wont open.
if all the water has gone, have a look behind the small flap on the front of the machine where the filter is and there might be a small plastic loop which when pulled should release the door catch.
please note i say might as some models have this feature and some dont.
hope this helps
Posted on Jul 25, 2008
SOURCE: washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Dec 17, 2008
  • 82 Answers
SOURCE: Model Thor1050 washing mach door stuck. How do I open?
Try bumping it. If that doesn't work, unplug the machine and then plug it back in.
Posted on Mar 14, 2010
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
SOURCE: Gallery washing machine door latch stuck in lock p...
I have the same problem with my Gallery. I can not open it at all. I have tried unpluging it and putting it through another cycle to see if it will open. No such luck. Any suggestions?
Posted on Nov 08, 2010
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
Siemens Washing Machine - door stuck shut
I've got the same problem and i cannot find a solution
Aug 04, 2015 | Siemens Washing Machines
Door of Washing machine doesnot opened
the door interlock has failed
other then try to leave it off and struggle with the door
you need sometimes to release it from behind
not easy sometime with some machines
the replace the door lock interlock catch
it will work fine then
Sep 19, 2014 | Siemens Washing Machines
Siemens se25m275gb
Dishwashers tend to get stuck on wash cycle if the water temperature is not reaching the level the wash program expects it to reach. This could be due to faulty heater or thermostat or both.
One test is to run the dishwasher on a rinse cycle (normal water temperature) and see if it completes it.
Refer this site for location and cost of heater and thermostat
https://www.buyspares.co.uk/siemens/se25m275gb80/catalogue.pl?path=463858:496324,183865:463966&model_ref=185092
Apr 12, 2014 | Siemens Dishwashers
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
I can't get the door open on our washing machine, a SIWAMAT XLS 1650. Is the locking mechanism electronic, or mechanical?
The locking mechanism is electromechanical. If the machine is switched on for its cycle & then off, it takes about 2 minutes to open. In normal course it should open it immediately. Your locking mechanism is stuck & needs to be replaced.
Sep 18, 2011 | Siemens Washing Machines
Looking to order a rubber door seal for a siemens washing machine model number WFXD5201UC. Cannot find a web site to order it from.
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door seal your enquiring about. They should have anything you need.
http://www.repairclinic.com/Bosch-Washing-Machine-Model-WFXD5200UC01-ID-691201-Parts
Thank you for choosing FixYa. Please take a moment to rate the assistance you received here today and good luck.
P.S. There are some helpful "how to" videos on youtube for installing this part as well.
Regards,
Macmarkus :)
Jul 23, 2011 | Siemens WFXD5200UC Front Load Washer
The door seal is leaking. maybe a zipper or similar got stuck and made a small mesh in the grey rubber seal. Where can I get this part?
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 28, 2009 | Siemens WFXD8400UC Front Load Washer
Washing Machines Logo
517 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
