The sound has cut out from my amplifier, is it expensive to repair?
    Sergeant:
  • 249 Answers
That depends on what has happened.
Begin by checking that the cables and leads are all attached correctly. It may be a simple loose joint.
If this is a separates system where the amplifier is a separate unit from the other devices, then makes sure that the correct component is selected (if there is a physical switch).
When you are satisfied that the amplifier is definitely not producing sound, then it is likely to need repair. Depending on the repair shop, you might be charged a lot of money. If your amp is still under warranty, take it to the dealer from where you bought it.
It will also depend on the initial cause of the problem. If something was connected to the amplifier that was not recommended, the front end may have to be replaced. That's a term to describe the delicate pre-amplifier circuits.
If non-compatible speakers were used, these may have had an effect if their impedance is not matched to the amplifier.
And if the volume (gain) was increased to 'see how loud it goes' then this may have damaged the output stage amplifiers.
Posted on Apr 16, 2014
Amplifier cuts of after 20 min playing
Sounds like a component inside is overheating. Might suggest taking to a car adio specialist to fix but could be expensive to repair. A new replacement maybe cheaper.
Sep 02, 2012 | Car Audio & Video
Power keeps cutting in and out
Sounds like u have some blown output transistors possibly. Check all connections especially Ground! If no luck have ur local repair technician have a look at it.
Feb 04, 2011 | Kenwood KAC-9103D Car Audio Amplifier
My sound keeps going off .so i have to swith off and on again
It can be the power amplifiers may be over heating and cut out. Try hooking up the powered PC speakers to the AUDIO line out of the TV to see if the sound cuts out there also, if it does cut out then the problem is in sound processor section which is part of the main board, expensive part. Try my suggestion and post back.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Jun 15, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a behringer modle GMX112 amplifier. When I
Expensive? Depends if the house burns down with it. Call the Fire Dept before the next time you turn it on. Kidding.
Only a qualified tech with an eyeball on the unit could answer the cost question. It sounds bad. Not only does the smoking component need to be identified but the cause of its demise might still exist.
Mar 17, 2010 | Audio Players & Recorders
Cooling Fan Not Working
There is a fan drive circuit in these that will control the fan speed depending upon the load on the amp. It sounds like this citcuit is defective, This unit should be sent in for service. Crown units are not the easiest to repair and I would not suggest it be attempted without prior experience. This should not be an expensive repair.
Dan
Jul 05, 2009 | Crown CE2000 Amplifier
Technics amplifier su-v98, cuts off at 22-24 desibls
The most common cause of this is defective coupling caps inside. These allow some DC voltage to pass through to the final amp stage. This DDC voltage is detected by the protection circuit and the unit shuts down. This unit will require service. Please note that this should be a simple and inexpensive repair. The cost should be less than $10 for parts.
Dan
Jul 04, 2009 | Technics SUV500 2-Channel Amplifier
Sound cuts out
Output short protection needs work.
Mar 29, 2009 | Audio Players & Recorders
Sound cutting out
Was the amplifier installed by a professional or shadetree installer?
May have tapped into wrong wire for amplifier turn-on.
Jan 02, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Can you help me?
Sorry to tell you this, but that sounds like your amplifier's DSP or DSP power supply/control circuitry has failed. DSP stands for Digital Sound Processing - Source Direct bypasses all internal amplifier digital processing, which is why you have sound here. Unfortunately, you'll want to brace yourself for an expensive repair, because DSP components are difficult or impossible to troubleshoot for a servicer, though sometimes it is something simple and quick.
If it's under warrantee, obviously it'll be covered - if not, you may still consider contacting the manufacturer for repair. They're often less expensive than local servicers.
Nov 26, 2008 | Audio Players & Recorders
Sound cuts off
OK,  That means there's some kind of crazy fault in the temperature sensing circuits. I'm afraid you'll have to take it someplace and have it looked at for a more thorough diagnosis.
Aug 31, 2008 | NAD C325BEE Amplifier
32 people viewed this question
 Grubhead
Grubhead
