Technics su a707
The sound has cut out from the amplifier (su a 707) is it expensive to repair it?
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Posted on Mar 15, 2008
paulm10
  • 73 Answers
SOURCE: Missing Operating Manual Technics SU-V4X
http://www.eserviceinfo.com/downloadsm/35463/Technics_SU-V4X.html
Paul
Posted on Jun 13, 2009
  • 4234 Answers
SOURCE: Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Posted on Mar 15, 2010
joyrexjj
SOURCE: Problem with amplifier Technics SU-V500
technics amplifier su-d5000 user manual
Posted on Dec 30, 2013
I think I've blown my internal fuse/s on my technics amplifier model number su-ch7. How can I fix myself?
http://elektrotanya.com/technics_su-ch7_sm.pdf/download.html
This will have the service manual. If you are not experienced in this type of repair, it will probably be far less expensive to take it to a repair shop.
May 19, 2014 | Audio Players & Recorders
I have a technics hifi su-ch900 everytime I play a cd or cassette or have the tuner the sound cuts out when its slightly loud, on low volume its fine. I have checked the cables and they are correctly...
I found a link to a CH900 that switched off completely.
If you are not a technician, please don't open the amplifier.
But I think it will be a simple repair. It is not the same problem, but it looks a little simelar.
http://www.electronicspoint.com/technics-su-ch900-switching-off-t53309.html
Also found a service manual, but not complete. Still here is the link
http://elektrotanya.com/technics_su-ch900.pdf/download.html
Oct 30, 2013 | Audio Players & Recorders
Technics Amplifier SU-VZ320 plays sound for a while and just cuts out sound. Tried switching off and on but no sounds comes through. Leave it off for a while then turn it back on get sound then cuts out...
puede ser un problema con la fuente de poder de la planta,con los parlantes,con los cables y terminales que conectan los parlantes con la planta ,puesto que la mayoria de amplificadores tienen control de temperatura y al sobrecalentarce se apaga por protecion y por eso ensiende por un rato y despues se apaga, por favor revice que los parlantes y los cables con teminales esten bien y no esten aciendo contacto
Oct 05, 2010 | Technics Audio Players & Recorders
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Technics amplifier su-v98, cuts off at 22-24 desibls
The most common cause of this is defective coupling caps inside. These allow some DC voltage to pass through to the final amp stage. This DDC voltage is detected by the protection circuit and the unit shuts down. This unit will require service. Please note that this should be a simple and inexpensive repair. The cost should be less than $10 for parts.
Dan
Jul 04, 2009 | Technics SUV500 2-Channel Amplifier
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Sound cuts when volume is turned up
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
47 people viewed this question
 Grubhead
Grubhead
