Question about Casablanca Fan 6672G Panama® Ceiling Fan
Fan speed slow and keep stuck on slow speed - Casablanca Fan 6672G Panama® Ceiling Fan
    Genius:
  • Casablanca Fan Master
  • 1,617 Answers
Check the capisitor!
Posted on Apr 16, 2014
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
My fan F-my143 slow speed and got stuck sound
try oiling the shafting and bushing of the motor, if this does not provide temporary repair, have the bushing and shafting replaced.
Apr 16, 2014 | Panasonic Dryers
2008 chrysler town country radiator fan don workin high speed
If you have a viscous fan hub attached to the fan then it will not be working at high speed as there will be enough air flowing through the radiator to keep things cool. They only really work at high engine loads and slow speeds (hill climbing ) and at stop lights where the air flow is nill
Jan 22, 2014 | 2009 Chrysler Town &
My Colt's engine heat increasing drastically when driving in slow speed/stucked in traffic jams...
Overheating at low speeds is an indication of coolant flow problem or air flow problems, check you radiator fan, fan relay and coolant level.If you need more help on fixing cooling fan I would suggest you to check out the below site HowTo section http://www.buyautoparts.com/howto/
Oct 14, 2013 | 2006 Mitsubishi Colt
How do I control fan speed?
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
The fan speed on a laptop can determine how it operates consistently and reliably.
You can slow it down or speed it up, based on the circumstances.
For instance, slowing down the fan speed may be useful in reserving processes or during a prolonged slow time.
Speeding it up is beneficial in keeping the laptop cool during ongoing use or high-traffic times. For the long term, find a happy medium for regular use, so you won't "psyche" out your computer by constantly adjusting the settings.
Click on the Start menu and select "Control Panel." Next, choose "Performance and Maintenance."
Select "Power Saver."
To slow the fan speed, locate the slider next to "CPU Processing Speed" and slide it down by moving across to the left.
To speed up the fan, move the slider to the right.
Press "Apply" and then "OK," if prompted.
Hope this helps
Nov 08, 2012 | Lenovo IdeaCentre Q150 PC Desktop
Engine temperature reaches to high before cooling cycle begins
could be a bad temp sensor or faulty thermostat. so by cooling cycle do you mean electric fan, or water circulation. a bad thermostat will slow circulation down causing overheat even if cooling fans are on. a bad sensor will not operate electric fan properly or at all and car will get hot at idle or slow speed and cooler at higher speed. Keep in mind that electric fans can turn on at any given time so KEEP ALL FINGERS AND LOOSE CLOTHIG AWAY at all times.
Apr 02, 2011 | Nissan Sentra Cars & Trucks
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
My computers cooling fan keeps speeding up and slowing down is that a good thing or a bad thing
I'm assuming your desktop has an AMD processor?
AMD have a process called "quiet and cool" this basically speeds up the fan when the processor is under load and getting hot or slows it down when the processor isn't working as hard.
Regards
Mike
May 26, 2010 | Dell Inspiron 531s Desktop Computer
Fan motor keeps running on Audi A4 2004
fan motor has a thermal switch which turns on the fan as soon as the engine heats up. what happened there is that the switch is stuck on the closed position which keeps the fan on all the time. you should go to a garrage and have the part changed.
Jul 20, 2008 | 2004 Audi A4
Casablanca Fan 6672G Panama® Ceiling Fan Logo
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
