Question about Refrigerators
I have a servis fridge freezer m7664 and the fridge is freezing over I have it on setting 4 out of 6 I have tried to defrost it is there anything else I can do
    Problem Solver:
  • 10 Answers
If the fridge is in a position where it is in contact or near a heat source the sensors will not function correctly. I assume it is a modern day fridge which are over sensitive. I had a similar problem and now run the fridge on low and defrost every few weeks after emptying it.
Hope this helps. Regards
Posted on Apr 16, 2014
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
  • 171 Answers
SOURCE: Servis Fridge not cold enough
Hi ruthcart1,
I'm Harvey the Master Plumber.
Your problem is: You have a free standing fridge freezer from Servis (silver) and the fridge doesn't seem to be as cold as it should be. The freezer is absolutely fine just the fridge even though you have adjusted the thermometer inside.YouI've had it maybe 3/4 years.
You're still under warranty. Modification now voids the warranty. I would call warranty repair. This should be their headache not yours.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Posted on Nov 14, 2008
SOURCE: servis 7665 fridge / freezer,
my fridge will not work lights frikers all times on outside and inside
Posted on Feb 23, 2009
SOURCE: fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Posted on Mar 18, 2009
Servis Fridge Freezer Model # M7973B-I/1 light flashing
Likely problem is the temperature setting control is failing.
Apr 04, 2012 | Refrigerators
Servis fridage freezer red triangle exclamation light flashing. please advise.
i have a servis fridge/freezer m7065 3x/w1.
the fridge light constanly flashes and partly defrosts,then it becomes working again and vice versa.?
Oct 02, 2010 | Refrigerators
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fridge not staying cool, freezer still freezing
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Servis fridge / frezer not colling or freezing
i would firstly do a complete defrost- incase there has been a fault with the frost free system. if after a full defrost it runs ok then there was a fault somewhere in the defrost system including either defrost heater, cut out or possible jammed circulation fan.
Feb 05, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Fridge and freezer both freezing
If your control is not turned up too high you likely have an insensitive one. In this case it needs to be replaced with a new one, not too serious.
Dec 18, 2008 | Kenmore Freezer 20.6 cu. ft. Manual...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
