Question about Sharp AN-K15LP - Projector lamp
How do i change my projector lamp - Sharp AN-K15LP - Projector lamp
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Posted on Aug 26, 2016
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
hi
this lamp has a small lamp pcb with a chip on it.
have u change the complete module or have just changed the bulb.
if you have just changed the bulb then u have to replace the small fuse on the chip.
this should help to reset the lamp timer!
Apr 07, 2015 | InFocus SP-LAMP-LP9 Projector Lamp for...
How do i reset lamp timer in my projector
  • From page 55 of the manual (http://www.projectorcentral.com/pdf/projector_manual_2451.pdf): Press the MENU button to display the "MAIN MENU", and then press the up arrow or down arrow button to select "OPTION2". Press the ENTER button to display the "OPTION2" menu, and then press the up arrow or down arrow button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds. The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Dec 13, 2013 | Panasonic PT-LB10VE Multimedia Projector
We have had this projector for 2 years. The projector will not turn on. It will turn green for 3 seconds then turn red and the lamp light turns red. I feel like the lamp could not already be worn? I was...
Whether or not you need to replace the lamp depends on how many hours of use it's had. You should be able to find the lamp time somewhere in the menu on the projector. Lamps for this projector are rated for 2000 hours (bright mode) or 3000 hours (Eco mode). In my experience they usually need changing at approx. 1500 to 1600 hours (bright mode). On Page 54 of the owners manual ( http://www.projectorcentral.com/pdf/projector_manual_4177.pdf ) are instructions for changing the lamp and zeroing the timer once it's changed. The lamp is Type number : DT00911. You should be able to get one from the manufacturer, the dealer you purchased the projector from, or specialty bulb and lamp stores. Be prepared. They aren't cheap, but it's better than having to buy a new projector.
Jan 14, 2011 | Hitachi CP-X450 LCD Projector
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
The projector sais change the lamp and that the
you need to buy a new lamp, and install it check manual for lamp type
Jul 24, 2009 | Hitachi CP-L850W Multimedia Projector
Projector
Go into the projector menu, OPTION and then select LAMP TIME.
May 30, 2008 | 3M Projector lamp Projector Lamp
No picture new lamp
try turning the projector on and wait for one minute. On the projector keypad, press and hold the Volume + and Volume - keys for ten seconds.
Apr 08, 2008 | InFocus ScreenPlay 4800 Multimedia...
Sharp AN-K15LP - Projector lamp Logo
55 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
