Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet 1500 hydrostatic mower at idle hear a clunk in back
While the mower is idling there is a clunking sound in the back - not by the engine. It is every 2 seconds. Not very loud. Frequency increases with engine speed, but can't hear it after engine is at 1/3 speed. The clunking sound doesn't get louder with faster engine speed. I haven't tried going forward or backward to see if it continues. The sound is like a hammer hitting a large metal component - like trying to put the deck into a different level selector and it falls into place. The mower is 2-1/2 years old, always kept in the garage.
3 Suggested Answers
  • 16 Answers
SOURCE: i have a cub cadet model 1450 hydrostatic it will
2 valves on top of trans under finders
Posted on Oct 17, 2009
oldmanewtoys
  • 414 Answers
SOURCE: My daughter gave me her old Cub Cadet model 2145
linkage is connected correct? Did it work prior correct? Did you prurge after changing fluid
Posted on Mar 05, 2010
Testimonial: "Well you were exactly right. I had to remove the two plugs on top and kept operating the lever until I got the oil to run out the top. Runs great."
We have a cub cadet a knocking sound is coming from the back when in gear. What could be problem. Sounds fine when idling
Trans axle is shot. Unfortunately they are generally not repairable as parts aren't even available and replacement units are expensive. A used unit is tour best bet.
Aug 08, 2016 | Cub Cadet Garden
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
Looking for the sensor schematics for a cub cadet series 1000, LT1050 hydrostatic lawn tractor. anyone help me?
Try looking at the directional lever at the Transmission. The PTO for the deck will shut off when shifting into reverse. You may have to simply disconnect or jumper the reverse switch depending on if it is normally closed or normally open. Try it both ways to see what works. Also check the engine oil level, The low oil level switch will shut the engine down if more than a quart low.
Feb 27, 2018 | Cub Cadet Lawn Mower Deck Drive Belt...
Adjust idle speed
on the top of the carburator there should be an adjustment to set the idle speed
Apr 25, 2013 | Cub Cadet Garden
I have a cub cadet RZT 54 that was purchased in the spring of 2009. The mower cranks and runs fine but the blades will not engage. Have looked at electrical connections and everything looks fine.
Do you hear a "clunk" when you engage the PTO switch, but the blades don't turn? If so, then check the mower deck belt - is it properly threaded, and tensioned by the idler pulley? If there's absolutely no sound when you engage the PTO switch, the problem is likely electrical (even though everything looks OK). The PTO switch, PTO clutch, and the reverse lockout switches (near the bottom of the fwd/reverse control arms) should be checked. I don't think there's a separate fuse for the PTO on your mower, but there may be a relay. Even though these parts and connections look OK, they can fail internally. Best bet is to get a multitester and check each of them with the ohmmeter function.
Jul 02, 2010 | Cub Cadet Garden
I have a cub cadet mower and it has the hydrostat trans drive and I hit a tree root in the yard and the tractor quit moving. The mower deck still runs so is there a belt broken or what could be wrong?
There are two belts - the main drive belt from the engine to the hydrostatic transmission, and the mower belt that runs from the engine to the mower deck. Sounds like the main drive belt broke or came off. It's not an easy job to replace because it's up against the chassis underneath, and you usually have to remove and replace some parts to get at it. Take a look under there, see if the belt's gone, and decide if you want to tackle it or have a shop do it.
Jun 12, 2010 | Cub Cadet Garden
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
154 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
