Question about Briel Chamonix ES-35 Espresso Machine
Brew head leaks at gasket,causing some water to bypass the coffee and leak around outside of brew head
The filter holder not pushed far enough ino lock position, also the basket doesn't quite hold 2 level spoons of coffee.
Thanks, David
Posted on Jun 19, 2009
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Jun 04, 2014 | Bunn VPR Coffee Maker
Water leaks from the top of the right side of commercial coffee maker
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
Keurig K10 water spills out top and sides while brewing
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
Mar 22, 2014 | Keurig Coffee Makers & Espresso Machines
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
When brewing with the X1, water starts leaking from the underside of the top where the brass filter holder connects to the machine. Tightening the 4 nuts did not help.
HI
More than likley its your brew head gasket that is leaking. Take off the 4 nuts you hust tighten and it exposes the brew head gasket. Make sure that you put the chrome piece on the same way you took it off. Clean the head good before you put the new gasket on or you could have trouble.
I would check ebay.
Jan 31, 2011 | FrancisFrancis! X1 - Stainless Steel...
My bunn coffee maker is just dripping when it is making coffee. Then the next time it makes it just fine.
Hello, I am wondering how long between times you are stating, as most Bunn commercial units, stay heating 24/7, and if water is not poured into the machine every couple of days, they will evaporate off water that is held in the tank. This drop in water level can cause short brewing, slow brewing, etc.. as the unit relies on a vacuum or suction to brew properly. You could also have a leaking tank gasket, or brew tube gasket, and it is seeping air into the tank, breaking the vacuum/siphon action, and then seals with water, or expansion at other times. Another cause would be scale build up, and pieces are floating in the tank blocking the flow of water, or your spray head may be clogging/clogged, which minor cleaning should take care of the sprayhead, and tube, or a major cleaning necessary for the tank.
Hope that helps, and thank you.
Mar 04, 2009 | Bunn VPR Coffee Maker
Machine Leaks
There's a little known thing called a "warranty", and if you take it back to the store, you can get another one FOR FREE!! or your money back - You get to choose...imagine that??
Feb 28, 2009 | GE 106591 Coffee Maker
Leaks under pressure
Hi
Your brew head gasket is leaking and needs to be replaced. remove everything and turn the machine on its top. Look ate the brew head inside there is a black gasket and it should be clean and flat. If its cut or curled it needs to be replaced. Not cleaning the brew head will cause this gasket to be cut and after a while it will curl and not seal.
Mar 02, 2008 | Solis Crema SL-90 Espresso Machine
Briel Chamonix ES-35 Espresso Machine Logo
596 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Dennis Fitzsimmons
Level 1 Expert
Tom Chichester
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
