Question about Karcher K2.26 Electric Power Washer
Leaking water The washer gun handle is leaking water when pressed,what is the problem? Can it be fixed? The model number is 015356-203.
The o-ring and the plastic insert is broken. They may not have a part replacement, may have to get a new gun. Take the gun apart and you'll see the problem.
Posted on Jun 20, 2009
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when the...
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
Jun 16, 2014 | Karcher PSI Electric Pressure Washer
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    How to fix 12POE-150 power washer leaking gun wand
    There are no parts available for the inside of the guns. All you can do is replace the gun.
    see parts in link.
    http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
    May 01, 2014 | FAIP 1500 PSI Electric Power Washer
    I have a pro 1600pwa no22049022491 and it leaks from the gun i took gun apart to find that the small tube comes up the handle inside bends then gos on the end of the trigger in the bend ther is a small...
    No parts for the gun. I'm not sure what model you have for sure, I don't recognize 1600 PWA, see link.
    http://www.ppe-pressure-washer-parts.com/job-mate-1600-power-washer-parts
    Apr 19, 2014 | Garden
    Have a Karcher kb4040 that continues to run constantly even when the trigger isnt pressed. Also water flows out of the detergant hose when im not pressing the trigger. Pressure seems down slighlty, not...
    This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
    Oct 13, 2012 | Garden
    Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
    There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
    Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
    I have a Karcher 110 pressure washer and when switched on to jet wash the water is coming out of the handle and just trickling out of the jet nozzle please can you help. Thankyou Brian Hills
    Which part of the handle is water leaking from? It could be that the hose connection into the gun is not fitted properly. Otherwise it could be that you just need to replace the handle.
    Feb 28, 2011 | Garden
    Water leaking from spray gun
    It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
    If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
    Jan 02, 2011 | Karcher Garden
    The handle leaks and seems to not have the tension on the handle. I have it apart and it seems like a tension string is broken but I can't see how it reconnects.
    They don't offer parts for the trigger guns, you would just need to purchase a new trigger gun. There is a number of different trigger guns for these machines though, what is the model and part number of the machine that you have?
    Oct 10, 2010 | Karcher 2500 PSI Pressure Washer
    Karcher K2.26 Electric Power Washer Logo
    1,041 people viewed this question
    Top Karcher Garden Experts
    John Trevino
    Harold Baxter
    Level 1 Expert
    Are you a Karcher Garden Expert? Answer questions, earn points and help others
