Reset belair20 router what is default ip adress
SOURCE: Can't access my routers configuration panel
If you want IP address of your wan port you can go to your command portion & just type a ? mark and then enter. You can get the proper command of this oparation. If you want your internet IP Address you can get it from the Internet connection icon / Call your ISP.
Better you try this & message me about results. I think IT ned some more discussions.
Posted on Feb 10, 2008
  • 84 Answers
SOURCE: factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
Posted on Feb 11, 2008
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Posted on Aug 10, 2008
  • 192 Answers
SOURCE: cannot access belkin 54g wireless modem settings
Try geting a routher that featres wirless and eathernet so you do not have to have two boxes. You will have to know its ip adress enter it internet explore and then you will be able to protect it through there.
Posted on Jan 04, 2009
  • 272 Answers
SOURCE: cant obtain ip adress
Have you set up your lynksys to allow wireless QoS? If not go to your lynksys broadband wireless software. If you don't know how enter 192.168.1.1 into your explorer bar, log in with lynksys, default is top line blank password 'admin', go to Applications and Gaming tab and enable Wireless QoS, you'll also see all of the places to establish and open ports for specific applications.
Posted on May 09, 2009
Adress is 192.168.1.254 iwhant ueser and password
type in a browser your IP address (192.168.1.254) a window should pop up asking for your credentials, Unless you have changed them they should be:
user: admin
password: (blank)
this is the default password for this router. If you have changed it (and forgotten it) , you can do a reset using a paper clip on the back of the unit. Note it will reset all settings back to the default setting.
Oct 04, 2011 | D-Link AirPlus DI-524 Wireless Router
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I WENT 2 RESET PASSWOOR OM MY AOPEN ROUTER WERE DO I GO 2 DO THIS
if your router's ip address is 192.168.1.1 then set you pc's ip adress to 192.168.1.2 mask 255.255.255.0 gateway 192.168.1.1. type http://192.168.1.1 in your internet explorer.choose reset factory default in you router's system menu.
Jan 18, 2011 | Computers & Internet
I want the ip to access my router so i can change the default name n put security
You can locate your router's adress with this easy trip:
Hit start - run - cmd. At the new black window that will appear type "ipconfig" without the quotes and hit enter. The system will reply with the the details for IP Adress, Subnet Mask and Default Gateway. The ip adress for Default Getaway is your router's ip adress. This photo may help you:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 01, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
When i type my ip adress on my adress bar, it does repond.
Try to press the reset button with help of any paper clip for 30Secs. and Release it, Take out power cable - plug back in. Open IE page try 192.168.1.1
WARNING: If you are pressing the reset buttono of router - it will take all your settings to default.
Apr 02, 2010 | Linksys WRT160N Wireless Router
I changed the IP address on belkin f5d8236-4 v2 and can't get into homepage to reset the IP adress. Please help. Thanks in advance.
Restore it to facgtory default:
Turn off power
Depress the reset button on the bottom of the router.
Keep the reset button pressed and turn the power on.
Release the reset button after 10 seconds.
The default IP should be 192.168.1.1 or 192.168.0.1
Default passwords vary, but it is usually "admin."
Hope this helps,
BReady
Mar 27, 2010 | Belkin Computers & Internet
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Factory settings for a Linksys RV042
Feb 11, 2008 | Linksys : RV042 4-Port 10/100 VPN Router...
Usr and pass
Reset the router to each default settings, there should a reset button in every router. Usually located at the back of the router or in every side. The default user: admin pswrd: admin or fill in blank(empty). the ip add should be 192.168.1.1
Rate me SOLVED
Nov 22, 2007 | Compex NetPassage 26G / iWavePort WLU54G...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
