Question about Garden
Berlan Astkettensaege How Can I fix an oil blockage on my pole pruner.I have cleaned it all up but there is no oil getting to the chain. Could the tube from the oil chamber to the chain be clogged?
    Sergeant:
  • 342 Answers
Gerard try running the saw and getting someone to spray some WD40 onto the chain as it spins.
Posted on Apr 19, 2014
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
The 8 angle anvil pruner sku #836-7013 has a design flaw. It is not a saw; it is not a chainsaw; it has Is there a pruner like this with a better design?
I think this is one of those cutter blade type of trimmers , I do know you have to keep blades razor sharp to cut anything with them , as they do tend to go dull easy (by design) , id go with a pole pruner chain saw if your looking to replace it , but beware as pruner chain blades and chain saws are not interchangeable due to fact that pruner's are made to cut on both sides of bar , chainsaws only cut on down stroke hence have a much more aggressive chain rake , don't put a chain for this on a pruner saw you'll be putting your self at risk of injury
Oct 08, 2015 | Garden
How to fix bar oiler
try cleaning the bar and all the oil gallaries in the bar and chainsaw body. Rinse the oil tank with varsol to clean dirt fron the oil intake strainer, reassemble and test. to test the oil pump leave the side cove, bar and chain off, start the saw and see if oil sqirts out when you rev the motor
Sep 29, 2015 | Echo PPT-265ES Pole Pruner
Chain binds when bar is tightened
visual check that the bar is not bent. ensure correct chain for the saw .different chains need different sproket tooth set ups. visually check this for proper full engagement.exactly how tight are you trying to get this thing? the chain may need a little slack to keep it from binding.
Jul 08, 2014 | Ryobi 2 Cycle Pole Pruner
Need Parts
For the pole saw parts go to the link Pole Saw
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Parts
this pole breaks because the gear inside is made of puter and when it gets warm enough it melts or breaks the teeth the only solution is to take it out and find some place that makes them to replace it
Instruction manual for pole pruner attachment
Do not use as a coaster.
Do not use to stabilize a wobbly table.
Your pole pruner is not edible.
Do not taunt your pole pruner.
Your pole pruner is not a parachute.
Do not feed your pole pruner after midnight.
Do not use pole pruner to commit armed robbery.
Do not name your pole pruner Carl.
Do not marry your pole pruner.
Do not turn your back on your pole pruner.
Jul 25, 2011 | Flamebrain Technologies WatchMe
Need manual for homelite ut43160. what kind of oil
Chainsaw chain oil. Never let it run low!!!
Mar 26, 2010 | Homelite Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
